Lumbar Support not working
Old Feb 2, 2020 | 06:35 PM
djisparky's Avatar
djisparky
Wink Lumbar Support not working
New member to CL. I recently purchased a used 14 IS250 and its lumbar control button is stuck. Its very stiff and won't move much on either direction. And of course the lumbar support don't work as a result. Has anyone taken apart the seats on 3IS? Any help in diagnosing the issue before I make a trip to the stealership? Im pretty sure its something to do with the button itself but I don't know without taking it apart I guess.
Old Feb 2, 2020 | 07:13 PM
Bluefuziio's Avatar
Bluefuziio
Could be a fuse somewhere broken. I'd recommend taking a look at a fuse diagram and finding the related fused. I know in one of my past cars when the seat wasn't working it was related to a damaged fuse. So see if maybe that could help you?
Good luck!
Old Feb 2, 2020 | 08:42 PM
djisparky's Avatar
djisparky
Good luck!
Thanks. The other seat adjustments work only the lumbar adjustment button having this issue. But i will check the fuses to be sure.
Old Feb 3, 2020 | 12:11 AM
Raghza's Avatar
Raghza
If the button is stuck and not moving, then the problem is not in the fuse, but in the button itself.
If it's not moving at all, maybe there's something that has gotten inside, like Coke or a grain of sand? If it's moving, but hardly, then there might be something broken or stuck inside the button. I would go do the dealership, because I can imagine getting inside the button is kind of a PITA.
Old Feb 3, 2020 | 01:22 AM
3ismd's Avatar
3ismd
try moving your seat all the way back and then move it back up to the front. i discovered this by accident when installing my tuxmats and my lumbar started to work magically lol
Old Feb 3, 2020 | 07:28 AM
djisparky's Avatar
djisparky
Tried that but didnt help unfortunately. Its still the same.
Old Feb 3, 2020 | 07:34 AM
djisparky's Avatar
djisparky
Yeah I’ll try using an air duster and see if it helps. I also found the lumbar button on ebay. If anyone knows how to replace it please let me know. Im sensing that dealership might charge a pretty penny for this.
Old Feb 3, 2020 | 08:09 AM
JNP1227's Avatar
JNP1227
My lower back heated seat portion stopped working and they just ordered a new seat since its a PITA to change out parts inside the seat. Lucky, it was covered under warranty but I remember the dealer said it was around 1500$ for the seat.
Old Feb 3, 2020 | 08:17 AM
djisparky's Avatar
djisparky
Thats my worry as well. I dont wanna change the whole seat just for a button. But its also hard on my back that after going back and forth to work i have backaches lol
Old Feb 3, 2020 | 11:18 AM
Sasnuke's Avatar
Sasnuke
It looks like everything on the side of the seat just clips into place.
Once you have the trim off hopefully it will be easy to swap the lumbar switch at that point. You might even be able to do it with the seat in the car.
Old Feb 3, 2020 | 06:15 PM
djisparky's Avatar
djisparky
Exactly what I needed! Thanks a lot. Mind if I ask where you get this from? If you do thats cool.
Old Feb 4, 2020 | 04:53 AM
Sasnuke's Avatar
Sasnuke
If I told you someone would have to kill me lol
Another member posted the repair manual and wiring diagrams here for download: https://www.clublexus.com/forums/is-...l-rm30g0u.html
I didn't get them from that thread, but it's the same repair manual regardless of the source.
You can download both the manual and wiring diagrams to keep on hand for future use.
Old Feb 4, 2020 | 10:05 AM
djisparky's Avatar
djisparky
Awesome!! Thanks a lot. This is very handy for sure.
Old Feb 6, 2020 | 01:08 AM
GR3Y5H3ART's Avatar
GR3Y5H3ART
super helpful...thanks
lomarica
Jul 5, 2010 02:53 PM
one wolf
Jan 21, 2008 05:13 PM
dandd2
Jul 23, 2005 06:23 PM
KPatel8483
Aug 29, 2003 02:07 PM
