Help Identifying noise
What would be your guess on the part that is failing?
Thanks.
Turning the wheel that much with the vehicle not moving puts a lot of stress on the suspension and steering components.
Were you stepping on the braking in the video?
I'm assuming the noise on sharp turns is when you're driving.
If I remember correctly, I was applying the brakes. Not sure why, another bad move?
The noise typically occurs when pulling out of a drive space in reverse, with the wheels fully turned( small parking garage), or when I make a very sharp turn say when I am turning around on the same street. I don't remember hearing it when I'm doing a rolling turn.
a few more details, My alignment seems fine the car doesn't sway one way or the other. There is no steering wheel vibration at any speed either or sloppy handling.
While you will get some noise, it will likely be much less than the first video.
Other than that it would be hard to say what the noise is without hearing it under the conditions it naturally occurs.
Although, it seems the vehicle drives perfectly fine otherwise, so I'm not sure if the clunk is even anything to worry about.
It seems the only time it does it is at full lock steering, which realistically doesn't account for much of your overall driving.
The AWD's like to make noise at full lock steering, but that's mainly due to the AWD system...and perfectly normal.
