Chirping Noise from Engine Bay
Old Oct 19, 2019 | 12:33 AM
davyjordi's Avatar
davyjordi
Originally Posted by Sasnuke
All's well that ends well...chances it will come back...in 6 years lol...at least you'll know what it is next time, in advance.
haha, i definitely won't have the car in another six years' time, but yes, now for future reference i know what signs to look for, however.
Old Oct 20, 2019 | 08:24 PM
Noeh's Avatar
Noeh
Originally Posted by HOMER350
Hide the problem? The point is there is probably no problem. Can't jump to conclusions that parts may be needing replacement because a little noise.
Pulleys and tensioners are still original parts on cars running +300k miles.
Personally seen dozens of cars be rid of the sqeak long term with the spray lube. Spray for about 2-3 second...done.
Still , sound advise to take a look. Not hard to replace the belt and of course inspect everything you touch .
Yes, hide the problem. Belts make noise because something causing premature wear. Dressings conditions the rubber temporarily but it doesn’t solve the source of the problem. If the belt is just worn from weather or contamination, then replacing the belt is the best solution. Lubing the belt is a no no.
SilverES06
12
Dec 19, 2015 10:03 AM
07sgm250
Mar 22, 2012 05:21 AM
07LXgs350
Jul 22, 2011 08:43 PM
tom07es350
Dec 9, 2010 08:33 AM
Gotcha350
Apr 16, 2010 11:26 PM
