Need New Battery?
Old Sep 19, 2019 | 10:01 AM
curio's Avatar
curio
Default Need New Battery?
Hello, I got in my 2014 IS-250 this morning and went to start it and it wouldn't turn over. Just got the "clickity click click" noise you get when the battery is dead. I just put a battery charger on it and waiting for it to fully charge. In a couple hours I'll try to start it again with a charged battery. Any recommendations for battery replacement? Any brands/types I should consider first? This is the first time I've owned a Lexus so I'm not sure how expensive a battery replacement gonna be. Hoping I can just stop by a Autozone and pick up a cheap battery. Any wisdom you can provide here is greatly appreciated. Thanks!
-Craig in KY
Old Sep 19, 2019 | 10:03 AM
E46CT's Avatar
E46CT
Just plug your make/model into any website and see which one you need. Pretty basic of a battery. any brand will do since they all come from the three major battery suppliers of the world. Everyone just puts their own sticker on it and charges what they want.
Old Sep 19, 2019 | 11:01 AM
curio's Avatar
curio
Also, any idea why the battery would've drained over night? Seems weird. Didn't leave any lights on or any electronics.
Old Sep 19, 2019 | 12:03 PM
E46CT's Avatar
E46CT
Could be parasitic draw or could be just plain your battery is old. either way, 5 year mark is time to replace it.
2014 ISs did have problem with the gateway computer causing a parasitic draw though. did you ever get that fixed
Old Sep 19, 2019 | 01:18 PM
Sasnuke's Avatar
Sasnuke
If you have Blind Spot Monitoring or Clearance Sonar, then the vehicle could potentially have the Gateway ECU issue...however, if the vehicle is already 5-6 years old and didn't have the issue, I doubt it would start now.
As stated above, 5 years is typical for a run of the mill battery is a climate that seems extreme hot/cold throughout a calendar year (-35C to 35C...give or take).
Unlike other luxury brands these are just your simple batteries...no fancy programming or seance's needed to get the car up and running again...just replace the battery and set the clock to the right time.
Definitely buy a good quality battery...the OEM battery served you this long, so can't really say it's a crappy battery...ok, so maybe not the best out there, but definitely gets the job done.
And yeah, battery can just randomly die...could be a bad cell, or just the dropping overnight temps as we head into Fall.
Old Sep 23, 2019 | 02:21 PM
wycy's Avatar
wycy
Do you need a radio code or to save presets and other settings and stuff before unplugging the old battery? Is there anything else I should do?
Old Sep 23, 2019 | 02:31 PM
Sasnuke's Avatar
Sasnuke
I would write down your presets cause I can't remember for sure if they get erased or not.
The clock will be wrong when you reconnect the new battery, but that's to be expected.
You won't need a radio code or anything like that.
Old Sep 23, 2019 | 06:38 PM
wycy's Avatar
wycy
Thanks for the quick reply. I unexpectedly had to replace my battery today so this was very helpful.
EDIT: Update, some trivial settings were lost but my presents stayed.
worker
Mar 22, 2025 02:26 AM
Bobdeei
Mar 19, 2019 01:24 PM
tradosauru
Jun 20, 2016 03:18 PM
trips1
RX - 1st Gen (1999-2003)
Dec 28, 2012 01:33 PM
diamondmit
Apr 2, 2009 02:17 PM
