Offset question
Old Aug 26, 2019 | 12:53 PM
VanIS's Avatar
VanIS
Default Offset question
Hi I have tried to search and found most are running 235 and 265 tires so can't seem to find the answer I want.
I wanted to buy a set of rims for my car. I need help with the offsets. I want no rubbing at all.
I am lowered on RSR down Springs. I have a 2017 Lexus IS 350 AWD
Font tire size will be 225/35/19 (19*8.5)
Rear will be 255/30/19 (19 *9.5)
What offsets would help ensure I dont have any rubbing front and back?
I was looking at possibly +35 offset front and +42 offset back?
Or can I go lower say +32 F and +40 back?
I would like the alignment to be within factory specs and get the wheels as flush as possible but with no rubbing issues with passengers in the car etc.
Thanks!
Old Aug 26, 2019 | 12:58 PM
cliffhokie's Avatar
cliffhokie
I think the +35 front and +42 rear would be safer and you could go up to 235 up front and 265/275 in the rear. I have 37 up front and 44 in the rear with 235F 265R.
Old Aug 26, 2019 | 01:08 PM
VanIS's Avatar
VanIS
Great thanks for that I was leaning towards that recommendation as you stated would give me the option of going up in tire size.
Only issue I have going to 235 and 265 is I am AWD and wanted to keep it at the same ratio (225 and 255) as the stock wheels so I would not create any issues with the AWD system. Not sure if going up a size to 235 and 265 effects this on the AWD system as well as the speedometer.
Sorry if any of this sounds stupid I am new to all of this and trying to learn.
Old Aug 26, 2019 | 01:21 PM
Sasnuke's Avatar
Sasnuke
Once the front and rear tires are the same (or close as possible) circumference, then the AWD will be fine.
Also, the difference in 225/35 and 235/35 is only about 0.4 inches, so not that much bigger. The AWD drive really won't notice a difference.
If you went with the smaller tires, then you could do +32 front and +38 rear.
The larger tires will still fit with those offsets, but to be absolutely sure there's no rubbing, +35 front and +40 - +42 rear will be perfect.
Old Aug 26, 2019 | 01:25 PM
VanIS's Avatar
VanIS
Man you guys are great thanks for all this!
Now really considering going up a size and using the +35 and +42 offset....
Old Aug 26, 2019 | 01:28 PM
cliffhokie's Avatar
cliffhokie
235/265 "shouldn't" matter even on AWD as the difference is only .8% diameter. For reference, I'm pretty sure that is the exact same variance as 225/35r19 up front and 255/30r19 in the rear. Plenty of us with AWD are running 235/265 combo for staggered setups. However, if you want the twin, 235/35r19 up front and 275/30r19 in the rear are identical to each other in height. Then it depends on your offset, drop, wheels, and how square your sidewalls are (based on brand/model tires) regarding whether or not you will rub. I think most of us get 265 for insurance that it won't rub, but I personally have enough clearance and will most likely go 275 for my next set in the rear. I can't say whether or not 275 will work with your setup or not, but you shouldn't have any issue with 265. I personally don't like 225/255 on 8.5/9.5 because it shows a mild stretch on tires that already border on rubber band thickness running 35 and 30 sidewalls. But that is up to you. Again, this is all what "should" work. Results may vary and this depends on unique variables based on your own setup.
Old Aug 26, 2019 | 01:30 PM
cliffhokie's Avatar
cliffhokie
Or when all else fails, see what Sasnuke recommends.
Old Aug 26, 2019 | 01:49 PM
VanIS's Avatar
VanIS
I didnt think about this and wouldn't want any stretch on the tires.
Given all this, I most liklely will go:
19*8.5 Front 235/35/19 +35
19*9.5 Rear 265/30/19 +42
This set up will allow for no rubbing as well as no tire stretch and still be conservative it appears from all the comments.
Old Aug 26, 2019 | 02:27 PM
Napalvr's Avatar
Napalvr
19x10 +42 265-30
19x8.5 +32 235-35 AWD RSR Downs. No issues whatsoever just to show how “stretched “ your setup might look
Old Aug 26, 2019 | 02:31 PM
VanIS's Avatar
VanIS
Thanks for the pictures really helps! No rubbing with 32 offset in the front? I will be going with a 35 offset in the front just to be safe.
Cheers
Old Aug 26, 2019 | 03:57 PM
Miintt's Avatar
Miintt
You should also consider wheel design for the front wheels when it comes to offset. When I got my wheels I went with a +35 offset because I didn’t want rubbing either but the wheels did not clear the brake calipers. I exchanged them with +30 offset and I have no rubbing with 225/35 tires. I’ll be moving up to 235s next time since I still have room
Old Aug 27, 2019 | 03:11 AM
Napalvr's Avatar
Napalvr
Cheers
Absolutely no rubbing in the front
IS350HKS
Nov 6, 2010 03:49 PM
flexspeed
Oct 1, 2010 04:53 AM
zebt66
Jul 20, 2009 04:54 PM
z4frosik
Jan 6, 2008 09:57 PM
FIVEOHinNJ
Aug 13, 2007 07:52 AM
