2014 is350f $18k?
Looking at a 2014 is350f ml audio, clean interior and exterior going for 18k only issue is it has 100k miles. This is a certified by Lexus and has a 120k mile warranty. Clean carfax. Is this a good deal? Am I paying too much for a car that already has 100k miles...
Merely opinion, but 18k sounds right to me with that many miles. On the other hand, its a Lexus, your problems will be few and far between aside from expected wear items. Also, be sure to reference the car appropriately... this is an F-Sport, not an F car.
Hope you find the car that best suits your criteria. Ive absolutely enjoyed mine.
Depends on how well you deal with maintenance or needed repairs. It is a good car, but with 100K you'll need to replace things like coolant hoses, water pumps, shocks, ball joints etc... in the next 20-40K miles. The cost won't be horrible, but you will have to get this work done. If you replace these you can get another 50-100K out of the car.
What is that time and effort worth to you? You can probably get a 2014 with 60K miles for about $22K, but not certified. Neither is a horrible choice, just make sure you understand the difference.
SERVICESERVICE HISTORY
Your vehicle maintenance history can be accessed by any Lexus dealer you visit. You can also use your Lexus Drivers account to view and manually enter additional records should you have service performed elsewhere.
ADD VIN
Options shown
Repair# 0381695
Reported By: Parker Lexus
Service: CAR WASH
Description: CAR WASH ~ ~COMPLIMENTARY CAR WASH ~ ~ ~ ~.
Service: DIAGNOSTICS 2
Description: DIAGNOSTICS 2 ~ ~CUSTOMER REQUEST DIAGNOSIS OF THE FOLLLOWING CONCERNS ~ ~ ~ ~.
Service: ELECT/MODULATED AIR SUSPNSN AIRBAG SYSTEM
Description: ELECT/MODULATED AIR SUSPNSN AIRBAG SYSTEM ~ ~CUSTOMER STATED HIS SEATS ARE STARTING TO TEAR AND HE WAS TOLD IT MAY BE COVERED UNDER WARRANTY I STATED HE WOULD HAVE TO INSPECT THE VEHICLE FIRST TO SEE IF IT MAY BE COVERED PLEASE CHECK AND ADSHOW LESS
Service: MPI INSPECTION
Description: MPI INSPECTION ~ ~PERFORM COMPLIMENTARY MULTIPOINT INSPECTION ~ ~ ~ ~COMPLETED COMPLIMENTARY MULTIPOINT INSPECTION. PLEASE SEE REPORT CARD FOR DETAILS.
Service: NAVIGATION COMPUTER
Description: NAVIGATION COMPUTER ~ ~CUSTOMER STATED HIS LCD SCREEN IS STARTING TO PEEL PLEASE CHECK AND ADVISE LEXUS EX-WARR VSA4IJ0667 ~ ~MULTI DISPLAY COATING PEELING FROM DEFECTIVE ANTI REFLECTIVE COATING ~ ~TSIB L-SB-0002-16 REPLACED MULTI DISPLAY SSHOW LESS
Service: NON WARRANTABLE OPERATION CODE
Description: NON WARRANTABLE OPERATION CODE ~ ~ ~ ~ ~ ~.
Repair# 0378245
Service: 90K MILE SVC
Description: 90K MILE SVC ~ ~CUSTOMER REQUESTS A 90K MILE SERVICE ~ ~CUSTOMER REQUESTS A 90K MILE SERVICE ~ ~PERFORMED A 90K MILE SERVICE PER CUSTOMER'S REQUEST
Service: CAR WASH
Description: CAR WASH ~ ~COMPLIMENTARY CAR WASH ~ ~ ~ ~C
Description: NON WARRANTABLE OPERATION CODE ~ ~LEXUS ~ ~ ~ ~AS A COURTESY TO YOU THE LEXUS LOANER CAR DAILY FEE OF 124.95 WILL BE PAID BY PARKER LEXUS. WE ASK THAT THE LOANER CAR BE RETURNED BY 5:30PM ON THE DAY REPAIRS ARE COMPLETED OR THERE COULD BE ASHOW LESS
Service: YELLOW BRAKES
Description: YELLOW BRAKES ~ ~BRAKES WILL REQUIRE FUTURE ATTENTION ~ ~ ~ ~WILL NEED ATTENTION NEXT SERVICE.
Repair# 0376679
Service: BATTERY/COIL SPK PLUG
Description: BATTERY/COIL SPK PLUG ~ ~CUSTOMER STATES HE WAS TOLD BATERY IS UNDER WARRANTY LAST REPLACED 9/12/16 RO#340080. 50% WARRANTY $155+TAX ~ ~BAD CELL FAILED CODE: D2UG-A0ED2-ENLTC ~ ~INTALLED NEW BATTERYBATTERY/COIL SPK PLUG ~ ~CUSTOMER STATES HE WAS TOLD BATERY IS UNDER WARRANTY LAST REPLACED 9/12/16 RO#340080. 50% WARRANTY $155+TAX ~ ~BAD CELL FAILED CODE: D2UG-A0ED2-ENLTC ~ ~INTALLED NEW BATTERY
Service: CAR WASH
Description: MPI INSPECTION ~ ~PERFORM COMPLIMENTARY MULTIPOINT INSPECTION ~ ~ ~ ~COMPLETED COMPLIMENTARY MULTIPOINT INSPECTION. PLEASE SEE REPORT CARD FOR DETAILS.MPI INSPECTION ~ ~PERFORM COMPLIMENTARY MULTIPOINT INSPECTION ~ ~ ~ ~COMPLETED COMPLIMENTARY MULTIPOINT INSPECTION. PLEASE SEE REPORT CARD FOR DETAILS.
Service: PARKER BUCKS
Description: PARKER BUCKS ~ ~PARKER LEXUS BONUS BUCKS ~ ~
Repair# 0373595
Service: CAR WASH
Description: CAR WASH ~ ~COMPLIMENTARY CAR WASH ~ ~ ~ ~COMPLETED
Service: F.DSC 1-SD INCL;R&R DSC PAD
Description: F.DSC 1-SD INCL;R&R DSC PAD ~ ~CUSTOMER STATES HE HAD BRAKE REPLACE IN THE FRONT IN OCTOBER LAST RO AND STATES NOW VEHICLE SHIMMIES IN THE FRONT PLEASE CHECK AND ADVISE. ~ ~WARPPED ROTORS ~ ~REMOVED BOTH FRONT TIRES,,REMOVED CALIPERS,RESHOW LESS
Description: NON WARRANTABLE OPERATION CODE ~ ~LEXUS ~ ~ ~ ~AS A COURTESY TO YOU THE LEXUS LOANER CAR DAILY FEE OF 124.95 WILL BE PAID BY PARKER LEXUS. WE ASK THAT THE LOANER CAR BE RETURNED BY 5:30PM ON THE DAY REPAIRS ARE COMPLETED OR THERE COULD BE A... READ MORE
Service: PK7S LOF
Description: PK7S LOF ~ ~CUSTOMER REQUEST OIL AND FILTER CHANGE ~ ~ ~ ~COMPLETED OIL AND FILTER CHANGE.
Service: RED A/C FILTER
Description: RED A/C FILTER ~ ~A/C FILTER REQUIRES IMMEDIATE ATTENTION ~ ~ ~ ~CUSTOMER WILL NEED @ SERVICE
Service: RED AIR FILTER
Description: RED AIR FILTER ~ ~ENGINE AIR FILTER REQUIRES IMMEDIATE ATTENTION ~ ~ ~ ~CUSTOMER WILL NEED @ SERVICE
Service: RED TIRES
Description: RED TIRES ~ ~TIRES REQUIRE IMMEDIATE ATTENTION ~ ~ ~ ~CUSTOMER WILL NEED @ SERVICE
Repair# 0370240
Service: 80K MILE SVC
Description: 80K MILE SVC ~ ~CUSTOMER REQUESTS A 80K MILE SERVICE ~ ~CUSTOMER REQUESTS A 80K MILE SERVICE ~ ~PERFORMED A 80K MILE SERVICE PER CUSTOMER'S REQUEST
Service: CAR WASH
Service: OTHERS
Description: OTHERS ~ ~ ~ ~3MM ~ ~REMOVED AND REPLACED PADS,SHIM KITS AND PIN LOCKKS.MACHINED BOTH FRONT ROTORS.
Description: RED A/C FILTER ~ ~A/C FILTER REQUIRES IMMEDIATE ATTENTION ~ ~ ~ ~CUSTOMER WILL NEED @ NEXT SERVICE
Description: RED AIR FILTER ~ ~ENGINE AIR FILTER REQUIRES IMMEDIATE ATTENTION ~ ~ ~ ~CUSTOMER WILL NEED @ NEXT SERVICE
Service: WHEEL ALIGNMENT
Description: WHEEL ALIGNMENT ~ ~CUSTOMER REQUEST 4 WHEEL ALIGNMENT ~ ~ ~ ~PERFORMED 4 WHEEL ALIGNMENT
Service: YELLOW TIRES
Description: YELLOW TIRES ~ ~TIRES WILL REQUIRE FUTURE ATTENTION ~ ~ ~ ~WILL NEED ATTENTION NEXT SERVICE.
Repair# 0362468
Service: 70K MILE SVC
Description: 70K MILE SVC ~ ~CUSTOMER REQUESTS A 70K MILE SERVICE ~ ~CUSTOMER REQUESTS A 70K MILE SERVICE ~ ~PERFORMED A 70K MILE SERVICE PER CUSTOMER'S REQUEST
Service: CAR WASH
Repair# 0358238
Service: 65K MILE SVC
Description: 65K MILE SVC ~ ~CUSTOMER REQUESTS A 65K MILE SERVICE ~ ~CUSTOMER REQUESTS A 65K MILE SERVICE ~ ~PERFORMED A 65K MILE SERVICE PER CUSTOMER'S REQUEST TAC3VB7647
Service: CAR WASH
Description: CAR WASH ~ ~COMPLIMENTARY CAR WASH ~ ~ ~ ~THANK YOU FOR YOUR BUSINESS!
Repair# 0354259
Service: 60K MILE SVC
Description: 60K MILE SVC ~ ~CUSTOMER REQUESTS A 60K MILE SERVICE ~ ~CUSTOMER REQUESTS A 60K MILE SERVICE ~ ~PERFORMED A 60K MILE SERVICE PER CUSTOMER'S REQUEST TAC3SW6724
Service: CAR WASH
Repair# 0348610
Service: CAR WASH
Description: CAR WASH ~ ~COMPLIMENTARY CAR WASH ~ ~.
Service: MISC
Description: MISC ~ ~COULD HERE RATTLE FROM ENGINE AREA IN DRIVE. SMELL GAS SMELL TOO ~ ~FUEL SMELL IS RELATED TO LINE #1 OPEN IN FILLER NECK VENT LINE. REMOVED DRIVE BELT AND FELT THE WATER PUMP PULLEY, CHECKING FOR SLACK IN THE PULLEY/BEARING. PULLEY SHOW LESS
Service: OTHERS
Description: OTHERS ~ ~CUSTOMER STATES THE CHECK ENGINE LIGHT IS BACK ON, ADVISE, CERT PRE OWNED ~ ~THE FILLED NECK VAPOR LINE HAS BEEN CUT IN HALF BY A PLASTIC BAG THAT WAS WRAPPED AROUND THE DRIVE SHAFT. ~ ~CUT LINE AND REPAIRED SO IT WILL NO LONGER LSHOW LESS
Repair# 0348506
Service: CAR WASH
Service: OTHERS
Description: OTHERS ~ ~FUEL CAP IS NOT SEALING PROPERLY. ~ ~FAULTY FUEL CAP SEAL. NOT SEALING THE EVAP SYSTEM CAUSING DTC'S. GROSS EVAP LEAK AND INCORRECT PURGE FLOW. ~ ~INSTALLED A NEW FUEL CAP O-RING AND CLEANED THE FILLER NECK TUBE WHERE IT SEALS. CO... READ MOREOTHERS ~ ~CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON, ADVISE HEARD CLICKING NOISE WHEN ACCELERATING OUT OF STOP ~ ~FUEL CAP IS NOT TIGHT. POOR FUEL CAP SEAL. ~ ~SEE LINE 5
Repair# 0347994
Service: CAR WASH
Description: NON WARRANTABLE OPERATION CODE ~ ~CUSTOMER REQUESTS MOUNT AND BALANCE ONE TIRE CUSTOMER HAD A BLOW OUT. L.R. TIRE. PARKER ROAD HAZARD. ~ ~ ~ ~MOUNT AND BALANCE ONE TIRE COMPLETED. DRIVER REAR. CONTNON WARRANTABLE OPERATION CODE ~ ~ ~ ~
Service: RED WIPERS
Description: RED WIPERS ~ ~WINDSHIELD WIPER SYSTEM REQUIRES IMMEDIATE ATTENTION ~ ~ ~ ~CUSTOMER DECLINED SERVICE AT THIS TIME
Repair# 0346864
Service: 50K MILE SVC
Description: 50K MILE SVC ~ ~CUSTOMER REQUESTS A 50K MILE SERVICE ~ ~CUSTOMER REQUESTS A 50K MILE SERVICE ~ ~PERFORMED A 50K MILE SERVICE PER CUSTOMER'S REQUEST TAC3OZ4343
Service: CAR WASH
Service: MISC
Description: MISC ~ ~BODY REPAIR SEE DUSTIN AND GENTRY ~ ~ ~ ~.
Description: NON WARRANTABLE OPERATION CODE ~ ~CUSTOMER STATES THEY HEAR A NOISE FROM THE RIGHT FRONT AT PARKING LOT SPEEDS OVER BUMPS IN RIGHT TURNS, ADVISE ~ ~COULD NOT DUPLICATE NOISE AT THIS TIME ~ ~WOULD NEED TO RIDE WITH CUSTOMER TO CONFIRM NOISE ... READ MORENON WARRANTABLE OPERATION CODE ~ ~LEXUS ~ ~ ~ ~AS A COURTESY TO YOU THE LEXUS LOANER CAR DAILY FEE OF 124.95 WILL BE PAID BY PARKER LEXUS. WE ASK THAT THE LOANER CAR BE RETURNED BY 5:30PM ON THE DAY REPAIRS ARE COMPLETED OR THERE COULD BE A... READ MORE
Service: REAR WHEEL ARCH
Description: REAR WHEEL ARCH ~ ~LEXUS HAS ISSUED A LIMITED SPECIAL SERVICE CAMPAIGN ON CERTAIN 2015 RC350, RCF VEHICLE AND CERTAIN 2014-2015 IS250 AND IS350 VEHICLES. ~ ~THE INNER PORTION OF THE REAR FENDER ARCH MAY EXPERIENCE WATER INTRUSION DUE TO IMP... READ MORE
Repair# 0340080
Service: A/C FILTER
Description: A/C FILTER ~ ~CUSTOMER REQUEST REPLACE A/C FILTER. ~ ~DUE TO TIME AND MILEAGE ~ ~COMPLETED
Description: BATTERY/COIL SPK PLUG ~ ~SLOW TO START ~ ~BATTERY FAILED TEST ~ ~REPLACED BATTERY, ALTERNATOR CHARGING FINE AT THIS TIME
Service: CERTIFIED PRE-OWNED PDI
Description: CERTIFIED PRE-OWNED PDI ~ ~USED VEHICLE CERTIFICATION ~ ~ ~ ~CERTIFICATION COMPLETED
Service: ENGINE AIR FILTER
Description: ENGINE AIR FILTER ~ ~CUSTOMER REQUEST REPLACE ENGINE AIR FILTER ~ ~DUE TO TIME OR MILEAGE ~ ~COMPLETED
Service: F.DSC 1-SD (OFF-VEH)
Description: F.DSC 1-SD (OFF-VEH) ~ ~VIBRATING ~ ~PADS 6MM, ROTORS BELOW MIN SPEC ON THICKNESS ~ ~REPLACED BRAKE ROTORS AND BRAKE PADS
Description: NON WARRANTABLE OPERATION CODE ~ ~DUE BY TIME ~ ~DUE BY TIME ~ ~COMPLETED REAR DIFF SERVICE
Service: SED WIPER SERVICE
Description: SED WIPER SERVICE ~ ~CUSTOMER REQUEST WINDSHIELD WIPER SERVICE. ~ ~SMEARING ~ ~REPLACE WIPER BLADE INSERTS, CLEAN WINDSHIELD THOROUGHLY AND APPLY RAIN-X TO WINDSHIELD
Repair# 0325920
Service: 40K MILE SVC
Description: 40K MILE SVC ~ ~CUSTOMER REQUESTS A 40K MILE SERVICE ~ ~CUSTOMER REQUESTS A 40K MILE SERVICE ~ ~PERFORMED A 40K MILE SERVICE PER CUSTOMER'S REQUEST
Service: CAR WASH
Description: CAR WASH ~ ~COMPLIMENTARY CAR WASH ~ ~ ~ ~E
Service: MISC
Description: MISC ~ ~LEE TO REMOVE DENTS IN HOOD TRUNK AND -EAR PASS DOOR. PAINTLESS DENT. ~ ~ ~ ~DONE
Service: SFI.MFI
Description: SFI.MFI ~ ~CUSTOMER STATES CHECK ENGINE LIGHT IS O N PLEASE CHECK AND AD VISE ~ ~HAD CODE P0441,P0455 FRO GROSS EVAP LEAK.LOOSE GAS CAP ~ ~TIGHTENED UP GAS CAP AND CLEARED THGE CODES,HAD FULL TANK GAS COULD NOT PERFORM EVAP TEST
Repair# 0319658
Service: 30K MILE SVC
Description: 30K MILE SVC ~ ~CUSTOMER REQUESTS A 30K MILE SERVICE NO BALANCE. ADV ON BACK TIRE ~ ~CUSTOMER REQUESTS A 30K MILE SERVICE ~ ~PERFORMED A 30K MILE SERVICE PER CUSTOMER'S REQUEST
Service: CAR WASH
Service: FRONT/REAR BODY
Description: FRONT/REAR BODY ~ ~CUSTOMER STATESDING IN DOOR. PLEASE CHECK AND ADVISE. HAS PAINTLESS DENT PASSENGER BACK DOOR. ~ ~ ~ ~FIXED/FRONT/REAR BODY ~ ~CUSTOMER STATESDING IN DOOR. PLEASE CHECK AND ADVISE. HAS PAINTLESS DENT PASSENGER BACK DOOR. ~ ~ ~ ~FIXED/
Service: PRE-OWNED LOF
Description: PRE-OWNED LOF ~ ~COMPLIMENTARY PRE-OWNED OIL AND FILTER CHANGE. ~ ~PERFORM COMPLIMENTARY OIL AND FILTER CHANGE BASED ON TIME AND MILEAGE. ~ ~COMPLETED COMPLIMENTARY PRE-OWNED OIL AND FILTER CHANGE.
Repair# 0315392
Service: A/C FILTER
Service: MISC
Description: MISC ~ ~FILL W/GAS ~ ~
Service: OTHERS
Description: OTHERS ~ ~ ~ ~ ~ ~REPLACED FRONT BRAKE PADS, FITTINGS AND TURNED FRONT ROTORS
Description: SED WIPER SERVICE ~ ~CUSTOMER REQUEST WINDSHIELD WIPER SERVICE. ~ ~ ~ ~REPLACE WIPER BLADE INSERTS, CLEAN WINDSHIELD THOROUGHLY AND APPLY RAIN-X TO WINDSHIELD
Repair# 0300578
Service: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
Description: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PERFORM PRE DELIVERY INSPECTION ~ ~ ~ ~COMPLETED PRE DELIVERY INSPECTION
Safety Recalls & Service Campaigns
© 2006-2019 Lexus, a Division of Toyota Motor Sales, U.S.A., Inc. All information contained herein applies to U.S. vehicles only.
SERVICE HISTORY FOR YOUR 2014 IS350
ADD VIN
Options shown
SERVICE HISTORY
Filter History By YearAllAll 2019 2018 2017 2016 2015 2014 201398548 MILES
08/06/2019Repair# 0381695
Service: CAR WASH
95531 MILES
05/08/2019Repair# 0378245
Service: CAR WASH
92938 MILES
03/29/2019Repair# 0376679
Service: CAR WASH
88808 MILES
01/14/2019Repair# 0373595
Service: CAR WASH
Service: PK7S LOF
Service: RED TIRES
84783 MILES
10/16/2018Repair# 0370240
Service: CAR WASH
Service: OTHERS
74199 MILES
03/26/2018Repair# 0362468
Service: CAR WASH
67690 MILES
12/06/2017Repair# 0358238
Service: CAR WASH
61096 MILES
08/29/2017Repair# 0354259
Service: CAR WASH
53356 MILES
04/14/2017Repair# 0348610
Service: CAR WASH
Service: MISC
Service: OTHERS
53151 MILES
04/11/2017Repair# 0348506
Service: CAR WASH
Service: OTHERS
52138 MILES
04/03/2017Repair# 0347994
Service: CAR WASH
Service: RED WIPERS
50492 MILES
03/03/2017Repair# 0346864
Service: CAR WASH
Service: MISC
45454 MILES
09/15/2016Repair# 0340080
Service: A/C FILTER
39733 MILES
09/09/2015Repair# 0325920
Service: CAR WASH
Service: MISC
Service: SFI.MFI
30833 MILES
04/07/2015Repair# 0319658
Service: CAR WASH
22400 MILES
12/10/2014Repair# 0315392
Service: A/C FILTER
Service: MISC
Service: OTHERS
9 MILES
10/22/2013Repair# 0300578
TERMS AND CONDITIONS
ABOUT LEXUS
FINANCE & LEASING
BRAND & LIFESTYLE
SERVICE
