Broken side view mirror need suggestions
Old Jul 29, 2019 | 06:21 PM
Dallasguy1's Avatar
Dallasguy1
Default Broken side view mirror need suggestions
So this happened today I have a base IS200 do I need to get the complete assembly or I can just change this piece. Thanks
Old Jul 30, 2019 | 09:01 AM
E46CT's Avatar
E46CT
As far as I knnow that's not sold seperately. Go to ebay and look for a used mirror. your best bet.
Old Jul 30, 2019 | 09:02 AM
E46CT's Avatar
E46CT
also keep in mind the CT, LS, ES, GS share the same mirror so you may be able to buy another mirror that's broken elsewhere, and swap over the parts you need.
Old Jul 30, 2019 | 09:41 PM
Dallasguy1's Avatar
Dallasguy1
Found this on eBay, this should solve since the mirror is not broken.
Old Jul 30, 2019 | 09:50 PM
BrettKA7's Avatar
BrettKA7
This happened to me the other day too. I ordered a replacement factory painted from Lexus of Scottsdale. Should have it Thursday and replacement looks straightforward!
the *crunch* it made when I hit the side of my garage was heartbreaking.
make sure you order the right paint code as there are several shades of black!
Old Aug 1, 2019 | 08:07 PM
BrettKA7's Avatar
BrettKA7
Just changed mine out! Let me know if you need any help.
When reassembling, I definitely recommend replacing the black plastic right behind the mirror first, then the lower part, then the painted part.
The light that illuminates the floor was a PITA for me. I had to mount it on the mirror first and then slide the lower black plastic piece in to get it to fit right. That light took me about 10 minutes itself.
Old Aug 1, 2019 | 10:48 PM
Dallasguy1's Avatar
Dallasguy1
I'm probably gonna take to the body shop waiting for the part. Or was it really easy. I have popped the mirror out on my older generation IS250 and it used to shake on high speeds lol. This would be the same I'm assuming starting from taking the mirror out first ? Thanks
Old Aug 2, 2019 | 04:55 AM
Sasnuke's Avatar
Sasnuke
It's a fairly easy DIY:
Start watching the video at 1:35
Old Aug 2, 2019 | 12:02 PM
BrettKA7's Avatar
BrettKA7
Mirror glass comes out, then 5 screws come out. It was easy but would have been nice to have one more hand hold things in place. I didn’t unclip the electrical connectors in the glass, I just slid the plastic pieces around the glass.
Old Aug 2, 2019 | 12:55 PM
E46CT's Avatar
E46CT
after replacing so many LEDs in the puddle lights i can now disassemble this mirror in seconds with my eyes closed. and put it back together. but i admit the first few times its like a jig saw puzzle.
my advice is the gentler you are, the easier it goes. when you try to force it/manhandle it, it fights. if you are gentle and sweet, everything comes together perfectly.
it's easy to misalign and not feel/know it. so make sure you look at it closely before you screw everything back together.
Old Aug 2, 2019 | 12:56 PM
E46CT's Avatar
E46CT
On my CT, i plan to remove the mirrors and paint them gloss black. the base, the frames, everything. DIY!
Old Aug 10, 2019 | 11:09 PM
Dallasguy1's Avatar
Dallasguy1
It was straight forward took me few minutes to figure out where to put the puddle light otherwise it was easy. Thanks for the help guys ur the best. Cheers ?
Bobjann
Jun 23, 2014 12:50 PM
zackteee
Dec 1, 2013 09:42 PM
subwoofers
Jun 25, 2008 09:14 PM
