Lowest wheel offset for stock suspension.
Old Apr 30, 2019 | 07:01 PM
hunodos's Avatar
hunodos
Default Lowest wheel offset for stock suspension.
Hey, I have a 350 f sport and I'm tryna put on the Asanti ABL-12 and wanted to the know the lowest possible offset on stock suspension without any rubbing, to make the wheels more concave. The sizes are 19 X 8.5 front and 19 X 9.5 rear.
Thanks!
Old Apr 30, 2019 | 08:18 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
19x8.5 +25 225/35/19 and 19x9.5 +40 255/30/19
Old May 1, 2019 | 12:26 AM
hunodos's Avatar
hunodos
Can I use 235 tire for front and 275 in the back?
Old May 1, 2019 | 03:10 AM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
235 front and 265 rear
Old May 1, 2019 | 01:16 PM
taktiks's Avatar
taktiks
I'm running the following:
Front: 19x8.5 +35 245/35 Sumitomo HTR Z
Rear: 19x9.5 +40 265/30 Sumitomo HTR Z
Rear clears just fine, fronts rubbed like crazy. Ended up trimming fender liner, rolling, and relocating fender tabs and no more rubs. 225 in front would have worked with no mods, 235 could work depending on the brand of tire you use. Any lower offset would require more stretch in the tires and more fender mods.
Old May 8, 2019 | 05:57 AM
hunodos's Avatar
hunodos
I was hoping to do 235/35ZR19 front and 275/30ZR19 rear. Is your car lowered or is it on stock suspension?
Old May 8, 2019 | 10:47 AM
evltwn's Avatar
evltwn
willtheyfit.com will help you with the differences between tire sizes and offsets. It will show how close the tires come to the suspension and how much it will stick out. You can also see the way the sidewall of the tires should be.
Old May 8, 2019 | 10:13 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
Your changing the factory ratio. I would go 235/35 and 265/30
Old May 8, 2019 | 10:15 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
Not sure why so many people are going with extra wide tires? I would keep the factory tire widths and only increase the wheel width. Some tires only come in 235 and 265 .. so in those situations it makes sense to bump up the width, but I would still opt for a 225/35 and 255/30 if you can.
mikelexF
IS F (2008-2014)
Sep 13, 2012 10:33 PM
istundra
Nov 24, 2008 08:22 AM
mikemareen
Jul 30, 2007 09:15 AM
AJ
Wheels, Tires & Brakes Forum
Jan 16, 2007 01:53 PM
pnwdawg
15
Jul 24, 2006 06:56 PM
