Best Alignment Specs??
Apr 7, 2019 | 12:22 PM
Hey guys getting an alignment this week, I’ve seen many threads about ppl doing “better” than Lexus’s recommended specs but a lot of the information is conflicting. My cars a 2015 IS350 FSport AWD, could someone recommend the “best” alignment specs?
Apr 7, 2019 | 03:16 PM
Lexus specs are the best:
Toe ..
Front RWD: 0.0
Front AWD: 0.05 (toe in)
Rear AWD/RWD: 0.18 (toe in)
Apr 7, 2019 | 03:34 PM
Quote:
Originally Posted by
TOPENDMS
Toe ..
Front RWD: 0.0
What about camber and stuff? in this thread is that exactly what you told them to do to yours?
https://www.clublexus.com/forums/sus...s-are-off.html
i thought u did something slightly different than Lexus recommendations but I don’t know a lot about this stuff so I might have misunderstood
Apr 7, 2019 | 05:49 PM
I did the Lexus specs. The machine graph will give you different results if the just try to go to the center point.
I have to check camber, but I wouldn't change it much. Only front is adjustable and only on AWD
Apr 7, 2019 | 06:00 PM
TOPENDMS
on the other thread you said your front camber is 1.2 would you have it set there if you did it again?
Apr 7, 2019 | 06:54 PM
Apr 8, 2019 | 01:20 PM
There's no "best" spec. Alignments are a spectrum. Just depends where on the spectrum you want to land. Tire life/comfort or performance/agility.
This is why you'll see all kinds of answers. Also a lot of "car guys" misunderstand alignments and spew all sorts of misinformation.
So the first question you have to ask yourself is "what do I want"
You also have to ask yourself what adjustments are possible on your particular make/model of car
Apr 8, 2019 | 03:52 PM
E46CT
kk great thanks for the info
TOPENDMS
Suspension and Brakes
12
Aug 4, 2019 03:02 PM
Snowrydr01
Jul 7, 2015 12:17 PM
arnieosp
Jun 8, 2011 11:52 PM
RU514
13
Feb 20, 2011 09:47 PM
Coconut
Jan 10, 2009 07:26 AM
