Frustrating break squeal - 2016 IS350
Old Mar 13, 2019 | 01:14 PM
spindos's Avatar
spindos
Default Frustrating break squeal - 2016 IS350
Hey guys, I recently purchased a 16' IS350 F-Sport and I must say - it's a fantastic car. Coming from a commuter hatchback, the difference between the two is night and day. However, I've been getting this frustrating and abnormally loud break squeal coming from what appears to be the rear end. I did a visual inspection of the pads and rotors and both appear to be healthy (22,000 miles on the car). What could the issue be? I saw a couple threads here on ClubLexus that said that others have had luck bringing it into the dealer to get serviced because there's a TSB for it.
TL;DR
- Brakes squeal/squeak even when the car is already warm. The noise tends to show more when I'm in reverse or when it's cold (gets SUPER loud).
- Separate note - is it normal for there to be so much smoke coming from the exhaust? Here in NorCal, the weather has been in the 50s but even after the car runs for about 5 minutes, there is still white smoke coming from the exhaust. Is this just condensation or should I be concerned?
Old Mar 13, 2019 | 02:14 PM
arentz07's Avatar
arentz07
TL;DR
Hey, if you "recently" purchased it, the dealership should be willing to take a look at the brakes. More than likely, there's something wrong with the rotors. I had a persistent squeal with my IS back when it only had 17,000 miles. The pads were fine, but the rotors needed to be resurfaced. I'm still on the same pads 9,000 miles later and have no squeal.
Congrats on the new car, btw.
Old Mar 13, 2019 | 02:43 PM
CarlitoIS's Avatar
CarlitoIS
TL;DR
That happened to me on my 2016 IS. It was a constant squeal after braking and it still continued after I kept driving. I did have to replace the brake pads but the noise started after Lexus changed one of my rear tires. I think they did something with the rotors not sure? Either way, I never went back to the dealer, the noise eventually stopped after weeks. But I'd go the dealer. I was too lazy to go.
Old Mar 13, 2019 | 07:15 PM
KYLexusMkr's Avatar
KYLexusMkr
TSB #L-SB-0034-18
TSB: Some 2013-2018 model year Lexus vehicles AWD F Sport models and non-F Sport models may exhibit a squeal/squeak noise from the front brake pads. For customers who find this characteristic objectionable, an updated shim kit is now available.
Just had this performed on my ‘17 and so far has solved this issue.
Old Mar 13, 2019 | 09:02 PM
spindos's Avatar
spindos
Originally Posted by KYLexusMkr
TSB #L-SB-0034-18
Thanks man. I was looking for the TSB. Super appreciate it.
Did they end up replacing the pads too or only the shin kit?
Old Mar 14, 2019 | 11:37 AM
Sasnuke's Avatar
Sasnuke
Not sure if your vehicle is RWD or AWD, but there are two bulletins out in Canada:
File Type: pdf
File Type: pdf
Old Mar 14, 2019 | 03:50 PM
aniks's Avatar
aniks
Where would one find the US version of these documents?
Old Mar 14, 2019 | 04:34 PM
Sasnuke's Avatar
Sasnuke
Maybe try Googling the TSB title..."Front Brake..."
Unfortunately the US and Canada numbering convention is completely different for TSB's, so I'm not much help for south of the border.
But for sure the US bulletin exists.
Old Mar 14, 2019 | 04:51 PM
KYLexusMkr's Avatar
KYLexusMkr
They originally were just going to do the shims, but did full front pads and shims. Why, I don’t know, they didn’t elaborate on it, just simply told me to go easy as they seat.
Old Mar 14, 2019 | 05:30 PM
spindos's Avatar
spindos
I see. Looks like the TSB for Canada tells the technician to replace both the front pads and the shims. Did you notice any difference after the service since they didn't resurface the rotors? Also, did you just do a drop-in at the dealership or did you schedule an appointment?
Old Mar 14, 2019 | 06:48 PM
KYLexusMkr's Avatar
KYLexusMkr
The main difference is the squealing is no longer an issue, stopping power appears to be the same, pedal feel is the same as well. Mind you as well, the vehicle had just over 30k on the factory rotors and pads, so resurfacing the rotors should really be a nonissue. I did schedule an appointment for the TSB, but only after having other issues that required me to drop into the dealership.
Old Mar 21, 2019 | 04:07 PM
spindos's Avatar
spindos
Cool. I scheduled an appointment with a dealership this weekend. Hopefully they'll service my car under the TSB. Service performed under a TSB should be free of charge, right?
Old Mar 21, 2019 | 05:17 PM
KYLexusMkr's Avatar
KYLexusMkr
Yes, the TSB is a free service, no charge to repair items included. The items with mine were all fixed under warranty and the TSB, no charges.
Old Mar 21, 2019 | 05:23 PM
spindos's Avatar
spindos
Gotcha. Did you have to tell the technicians that you would like to get the car serviced under the TSB or receive any trouble during that process? I just don't want to end up having to pay for any diagnostic charges or walk out empty-handed. Thanks.
Old Mar 21, 2019 | 05:24 PM
Sasnuke's Avatar
Sasnuke
Just make sure you complain about a brake noise as the TSB describes...if there is no complaint they likely will not apply the TSB. No complaint means no problem, which means no TSB applies.
