IS 350 tires
Just bought a fresh set of Conti DWS06 yesterday. I don't know if its just the tires or a combination of tires and an alignment but these ride much smoother than the stock tires. Like, muuuccchhhh smoother. I got on the gas a little to see if they'd make any noise, but they were super quiet. It's still too early for me to review them properly, but initial impressions are:
Quiet
Zero play in the steering wheel
Quiet
Quiet
Quiet
And... I just realized you're in Canada.
Converting those to Canadian, I get:
- Costco: $1024.57
- Tire Rack: $842.04
If you buy now, Conti has a special $100 rebate in the form of a prepaid visa. I went to Canadian Tire, they had the cheapest price and best warranty.
I'm also looking for some tires for my car. I'm torn between the Conti's DWS06 and the Pirelli P Zero A/S.
Tirerack did a comparison between those two, the Michellin Pilot Sports A/S 3+ and Bridgestone Potenzas. It looked like overall, the pirelli's did pretty well:
https://www.tirerack.com/tires/tests...y.jsp?ttid=230
However, I know very few people with Pirelli's, so I'm trying to find out more info before I buy!
My mechanic, who is a proud Italian-Canadian and loves Italian autos, advised me against the Pirelli's. Based on my research, they were my first choice too. He said they perform very well, but that I'd be lucky to get 30k KM out of them. I really don't want to have to buy new tires that often.
I'll echo what others have said before that the DWS06 are great for a compromise between performance and comfort as far as UHP A/S tires go. I only drove on them once, but I noticed the difference in impact harshness right away. They are good in the snow as well. If you want a sportier driving experience they might not be ideal however. Don't get me wrong, they are still a performance tire, but there are sportier options, like the Michelins in particular, or the BFGoodrichs if you want to spend a little less.
Quick question, I have the DWS tires with <8K miles and still around 6-7/32 tread. They sound like tractor tires. Do others find tires to be noisier in winter than summer? Temps here get into the single digits and below zero.
All tires will be noisier when it's colder. The compound gets stiffer the colder is outside.
Like Arentz07, I have the BF Goodrich tires which do the job for me up here in New England. I eventually wanted to switch to Michelin Pilot Sports A/S 3+ but the BF Goodrich Comp 2 A/S hold up well against big potholes, snow, hard braking/cornering for me so I may not switch over to Michelins.
IMO,unless you have the GSF/RCF or RR Racing bushings installed I dont see a reason to buy expensive tires since you will be replacing them more frequently than you want.
I just replaced my Michelin A/S 3 + with Continental Extreme Contact DWS 06 today. I went with the DWS because of slight chance of dealing with snow when in the mountains but now I am having second thoughts. The steering is loose and I am not confident in the car. Tonight it rained and they lost grip a few times going around 70 on a steady (not hard rain). The Michelins handled better and I cant stand the loose steering. I want to take them back.
I found that increasing the tire pressure a bit helps somewhat (I found 4psi over the door placard value pretty good, but that is on a car with 20” wheels, not my 3IS, so you’ll have to experiment to see if you can find something acceptable).
All seasons are going to be your best bet, but it's not going to be drastic. Low profile tires are just plain loud vs. fatter camry tires. We drive performance RWD sports sedan so naturally they'll be a bit on the loud side.
As far as PSI, just go with whats on the door jamb, for quietness. more psi over recommended=definitely louder.
