Traction Icon and Center Clock Question
Old Jan 3, 2019 | 11:30 AM
t4tran's Avatar
t4tran
Default Traction Icon and Center Clock Question
This morning, I notice that my center clock does not work. I can't adjust the minutes or hours with the side buttons. Is the clock control by a fuse or something that I need to look into?
Second question, my traction icon (attached photo) seem to be on constantly. I cannot turn it off in the center console option next to the SNOW button. Is there any trick to turning it off?
Thanks in advance!
Old Jan 3, 2019 | 03:44 PM
Rh209216's Avatar
Rh209216
Do you have any aftermarket accessories or had any work done previously? The light being constantly on means the traction control system is off due to a malfunction. I saw you're also having problems with the keyless entry on the other tread.. at this point I would honestly start by checking all the fuses. All of these problems could be related if they share part of a circuit like a fuse, ground, or even the main body ecu.
Old Jan 5, 2019 | 01:43 PM
t4tran's Avatar
t4tran
I did had some work done with installing fog lights. I check all the wiring and they are correct. Maybe resetting the ECU helps? I check all fuse are good..Just really strange.
Browninggo
RX - 3rd Gen (2010-2015)
Nov 25, 2013 12:40 PM
esssee400
Jan 11, 2011 08:42 AM
golfkid777
Sep 17, 2010 12:08 AM
jdub20tx
Apr 7, 2009 02:46 PM
