Center console rioja red trim
Old Dec 13, 2018 | 03:25 PM
TonyN's Avatar
TonyN
Default Center console rioja red trim
Added a little bit more rioja red trim, I removed and covered the silver center trim and covered it with rioja red vinyl, color match is almost perfect.
material cost is $4.99 for a yard of vinyl ( I still have enough to do another set or something else in the car) and $10 can of all purpose adhesive spray, took about an hour from disassembly to install.
Some pictures with and without flash.
Old Dec 13, 2018 | 04:14 PM
E46CT's Avatar
E46CT
you know people are gonna ask.. link to vinyl? Not a bad match.
Old Dec 13, 2018 | 04:54 PM
WhyHateTho's Avatar
WhyHateTho
Looks good champ. Well done.
Old Dec 13, 2018 | 06:09 PM
TonyN's Avatar
TonyN
Local hole in the wall that has a ton of vinyl, I tried hobby lobby, jo Ann's, and Michaels, only this hole in the wall had it.
Thank you
Old Dec 13, 2018 | 07:14 PM
GibbsLexus's Avatar
GibbsLexus
Looking good
Old Dec 13, 2018 | 08:41 PM
TonyN's Avatar
TonyN
Originally Posted by GibbsLexus
Looking good
thanks you
Old Dec 13, 2018 | 11:09 PM
Raghza's Avatar
Raghza
It looks really good, what a great idea!
Did you also add some soft material under the vinyl? I imagine it would feel even nicer to touch, if it had some softness
Old Dec 13, 2018 | 11:46 PM
anthonys2r's Avatar
anthonys2r
Look good! I wonder how itll hold it in the Arizona summer sun though...
Old Dec 14, 2018 | 01:16 PM
E46CT's Avatar
E46CT
Thank you
so the local hole in the wall fabric store sold "rioja red" vinyl specifically for lexus enthusiasts? or is that just what you are calling it lol.
i figured you were specific in the name so it was made just for Lexus people..
Old Dec 14, 2018 | 03:15 PM
TonyN's Avatar
TonyN
I tried it but since the panel is such a tight fit, adding any more material would prove difficult to fit it back on the car and have it fit like factory. The vinyl alone has some backing so it is “soft touch" as is.
Should be good, i used locktite all purpose spray adhesive that has been used on other projects of mine and has held up great in Arizona summers. This is just tyical automotive vinyl, as long as I UV treat it like my other stuff, Ido not see it having any issue.
it didnt even have a name, I just took one of the back seat headrest with me into the store and went to the vinyl section. I did ask them the name and they said it's been there for a while and have no idea if they could even get more, the role was half gone.
4 stores in total and this one has the closes match, I would put it above a 95% match to the seats, and closer to 99% match to the door armrest since the grain in the material matches the door more.
Old Dec 14, 2018 | 03:28 PM
TonyN's Avatar
TonyN
Lighting conditions and material grain plays a big part on color and perception, overall it's almost identical.
I have about half a yard left, might buy more if I see anything else I want to wrap, I'll ask to see if they know the manufacture and name so I can pass the info along, last lady had no clue.
Old Dec 18, 2018 | 09:20 AM
darkfire's Avatar
darkfire
I always thought the shifter should be wrapped in Rioja Red as well instead of black.
Old Dec 18, 2018 | 09:37 AM
TonyN's Avatar
TonyN
thought about it but I don’t see a way to do it unless I tally cut up the leather to remove it.
Old Dec 18, 2018 | 09:49 AM
darkfire's Avatar
darkfire
Yeah, definitely wouldn't try it either. Just thinking out loud I suppose.
Old Dec 18, 2018 | 01:54 PM
BlazeL's Avatar
BlazeL
How did you remove these two pieces?
