Making additional 2 holes for license plate frame?
Old Jul 16, 2018 | 08:55 PM
yohan81718's Avatar
yohan81718
Default Making additional 2 holes for license plate frame?
I bought the frame which lets you put on all 4 screws down but my IS350 only came with 2 holes on top. Would you drill a hole to make it look flush and hold it tightly instead of hanging down or just keep it with 2 holes as is?
Old Jul 16, 2018 | 09:31 PM
a1rh3adsz's Avatar
a1rh3adsz
I don't think you can make two additional hole, because the plate bracket is only 1/2 to 3/4 the size of the license plate.
Old Jul 17, 2018 | 07:55 AM
RKSTRAT's Avatar
RKSTRAT
Just checking. You want to drill new holes in your trunk lid?
And install grommets?
I am just using the top two screws and the plate looks flush.
In fact I am using bumpers to keep the plate from hitting the trunk lid.
You can find custom frames that hide the bottom two screw holes on the license plate.
Also you can put dummy screws/nuts into the bottom holes just to fill them.
These would be plastic screws so that you could trim them flush at the nut.
Also add bumpers to protect the trunk lid.
Old Jul 17, 2018 | 09:00 AM
MedicalDoc's Avatar
MedicalDoc
No need to use all 4 holes.
Old Jul 17, 2018 | 09:24 AM
yohan81718's Avatar
yohan81718
I just want the plate to be held more securely and also rattle free in the future. My question was mainly whether drilling additional holes would damage the trunk significantly. I know some spoiler requires drilling holes too, so I assume the answer is no, but wanted to see if others have done it.
Old Jul 17, 2018 | 09:53 AM
Jay89's Avatar
Jay89
What I've done on my other car is use that super strong exterior double sided tape between the trunk and plate, and another strip between the plate and frame to keep it from moving. Then I glued a couple of those license plate screw covers on the bottom so I dont have just bare holes
YODAONE
Nov 29, 2017 01:24 PM
Rsianez
IS F (2008-2014)
Dec 1, 2016 03:13 PM
lester123
RX - 3rd Gen (2010-2015)
Apr 11, 2014 02:35 PM
CanadaDC
Mar 1, 2014 02:01 PM
sjgIS350
Feb 19, 2006 04:29 PM
