Intake
Old Jul 6, 2018 | 02:22 PM
  #31
Flash5's Avatar
Flash5
Originally Posted by KYLexusMkr
This maybe a dumb question but I’ve gotta ask. Can these not be used in the IS300 awd’s? Seen where they’re only listed for 200’s and 350’s. I figured it would be same application for the 300 V6 as the 350 V6 or am I wrong? Any insight would be appreciated.
I'm pretty sure all 3IS' can use the F Sport filter. Haha
Old Jul 6, 2018 | 02:34 PM
  #32
KYLexusMkr's Avatar
KYLexusMkr
I guess I should’ve clarified. I was wondering if the whole kit, tube, box, and filter would work. Lol I like the looks of it, but I did a search on K&N’s site and they don’t offer it for the 300’s but they do for the others, while the Lexus states the 200 and 350 as well. I’d just hate to order one and it not work, then be stuck. Thanks for the help btw.
Old Jul 6, 2018 | 02:40 PM
  #33
Flash5's Avatar
Flash5
Ohhhhh you mean the actual F Sport intake kit. I am not sure about that one as I only know the filter itself is compatible with all the 3IS. What year is your car?
Old Jul 6, 2018 | 02:52 PM
  #34
E46CT's Avatar
E46CT
Google the part #s for all the individual parts on the 300 vs 350 which the F Sport intake applies to. intake tube, box, couplings, etc. same? then it should fit.
Old Jul 6, 2018 | 03:16 PM
  #35
KYLexusMkr's Avatar
KYLexusMkr
I will have to give that a try! Thanks again!!!
Old Jul 6, 2018 | 04:33 PM
  #36
KYLexusMkr's Avatar
KYLexusMkr
Okay, so after some digging, the parts are interchangeable between the IS350 base/F-Sport and the 300 of the same. I do appreciate all the help, looks like I’ll be going ahead with my purchase. 😁
Old Jul 6, 2018 | 09:03 PM
  #37
HOMER350's Avatar
HOMER350
I wouldn't go K&N or oiled. It's risky in my opinion. No two people will oil it the same, enough, or too much. Oil on the MAF is something you definitely want to avoid if you put too much. And there's no real definition of "too much."
Go F sport! Set it and forget it. Clean (spray cleaner and rinse) every 10k or so.
Shoot now I feel like I should of went with Fsport filter. It was the 2nd day owning the car and well K&N was available across the street at the auto parts store
I've never oiled a filter I'll have to look up how often it needs to be done.
Old Jul 6, 2018 | 09:05 PM
  #38
HOMER350's Avatar
HOMER350
Also, where is this charcoal filter and am I safe to remove it on my 350? Do I even have one? Ha.
Old Jul 6, 2018 | 09:07 PM
  #39
Flash5's Avatar
Flash5
You should have noticed it when you took the air box apart if you didn’t see it then I guess you don’t have it?
Old Jul 6, 2018 | 09:26 PM
  #40
HOMER350's Avatar
HOMER350
Only thing I saw was the existing filter....which I was so excited to get the other in there I tore it out and swapped in 6 seconds.
Is it filtering the inlet to the intake tube? Underneath/ behind the normal air filter.
I should probably just so my research.
Old Jul 6, 2018 | 09:27 PM
  #41
Flash5's Avatar
Flash5
https://www.clublexus.com/forums/gx-...ntake-box.html
Old Jul 6, 2018 | 10:03 PM
  #42
HOMER350's Avatar
HOMER350
Thank you. and nope...wasn't there when I opened mine.
Old Jul 20, 2018 | 04:17 PM
  #43
blkout250's Avatar
blkout250
Default Help
Hey guys so I bought the f-sport filter for my is300 and I still cant heard the turbo is there anything else I have to do??
Old Jul 20, 2018 | 04:20 PM
  #44
Flash5's Avatar
Flash5
F sport filter isn’t going to increase turbo sound. You would have to get an aftermarket short ram intake (Injen, AEM) to hear the turbo a lot more. Or you can try the cutting a hole in the lower portion of the stock intake box (don’t recommend).
blkout250
Nov 19, 2018 06:40 AM
silkx3
Performance
18
Sep 19, 2016 10:18 AM
01a4man
Mar 3, 2011 05:34 PM
gkkid808
IS - 1st Gen (2001-2005)
Dec 22, 2009 09:15 PM
