Brake Dust Cover
Old Mar 7, 2018 | 04:54 PM
stephenmat's Avatar
stephenmat
Default Brake Dust Cover
I need to replace a brake dust cover. does anyone know where the instructions to do this would be I can not find it ANYWHERE. 17 is 300 f sport.
Old Mar 7, 2018 | 06:52 PM
ISFLexy's Avatar
ISFLexy
I've never done it on my IS before, but other cars i have and i would imagine its somewhat the same steps. Basically you have to remove the caliper, then rotor and then you should have access to the bolts holding the brake dust cover on. I remember on the last car i did this they were 10mm bolts, 4 of them.
Hope this somewhat helps you and points you in the right directions, but someone that has done it to the IS can confirm its the same would be great!
Old Mar 7, 2018 | 07:12 PM
loophole35's Avatar
loophole35
Unfortunately I believe the heat shield is sandwiched between the hub/bearing assembly and knuckle. You will need to remove the hub assembly from the knuckle which in your case means partial axle removal as well.
Old Mar 7, 2018 | 07:18 PM
Sasnuke's Avatar
Sasnuke
Is your car RWD or AWD? Are you doing the front or rear? Isn't the car still under warranty?
Assuming it's RWD and you are doing the front, them the caliper and brake rotor need to be removed.
Disconnect the ABS sensor connector from the back of the hub and remove the 4 bolts. The wheel bearing assembly can then be removed, and viola, there is the backing plate.
Reinstall in reverse order torquing everything down.
Twix
16
Dec 5, 2009 07:38 AM
LexInTex
Apr 18, 2008 07:24 PM
Joeb427
Oct 5, 2007 06:43 AM
KevinLe
Suspension and Brakes
Aug 13, 2007 10:00 PM
Captain57
Jul 6, 2006 06:27 PM
