Climate control AC buttons sticking (getting stuck and not rebounding)
Old Oct 27, 2017 | 12:29 PM
Chedeng88's Avatar
Chedeng88
Question Climate control AC buttons sticking (getting stuck and not rebounding)
Particularly the "AUTO" climate control button and the "lower fan speed" button. Both buttons noticeably take more effort to press compared to the rest and they get stuck and do not rebound after pressing. So when I turn on AUTO, it gets stuck and it's hard to turn off. I had to quite forcibly tap it a few times and slowly assist it up. The "lower fan speed" button is basically the same. This is on a 2014 IS350 AWD F-Sport.
Anyone having the same issue? I'm planning to call the dealership in a bit to see if this can be repaired/replaced under warranty.
Old Oct 27, 2017 | 06:31 PM
manchild's Avatar
manchild
Have you tried cleaning around the buttons with a playing card or a pin or something thin?
Old Oct 28, 2017 | 12:56 PM
Sango's Avatar
Sango
Check with the Lexus dealer if you can get the unit replaced under warranty.
Old Oct 28, 2017 | 05:11 PM
Ciggy's Avatar
Ciggy
Same problem. Dealer will attempt to spray some actuator lubricant in there that may or may not work. It kind of helped in my car. I don't use the buttons often it hasn't bothered me enough again to push LExus to fix it.
Old Oct 30, 2017 | 08:21 AM
Chedeng88's Avatar
Chedeng88
I just dropped the car off this morning at my Lexus dealership. They're going to replace the whole climate control panel assembly under warranty.
zes
19
Apr 26, 2017 10:57 AM
dashmer
May 25, 2014 09:40 AM
amart79196
GS - 1st Gen (1993-1997)
Sep 8, 2008 07:51 PM
Black94RX-7TT
Feb 1, 2006 07:54 PM
toy4two
RX - 1st Gen (1999-2003)
Nov 14, 2004 06:48 AM
