"Auto" Climate Control oddity
Old Nov 13, 2004 | 11:18 PM
toy4two's Avatar
toy4two
Default "Auto" Climate Control oddity
Why does the A/C Button ALWAYS come on when I use the Auto setting for the climate control in my 2000 RX? I mean I have it cranked up to 90 degrees and the freaking A/C light is on. Why would Lexus do this? Put more stress on the A/C components, reduce my gas milage, force more recharges of r134a. ???
Old Nov 14, 2004 | 05:12 AM
mhc0725's Avatar
mhc0725
Question AC Light
Do you mean you can't turn the AC off, or the sequence of the function itself bothers? The AC is set to be on whenever you press the AUTO button, no matter what temp you set it at. After pressing the AUTO, you can then press the AC button and the AC will be off while the auto climate control is still on.
The AC and AUTO shouldn't restart everytime you shut the engine and restart. Once you've pressed AUTO and AC, the climate control will be on each time you start up. So, if it's winter and you're always having it set at HOT, then just leave it alone. You can still adjust the temp without affecting the AUTO.
Old Nov 14, 2004 | 06:48 AM
rxdriver's Avatar
rxdriver
The automatic climate control will use the A/C as much as possible. Even if it's not being used for temperature, the system will use it as a dehumidifier. It will do that as long as the temperature outside is above freezing.
Yes, that probably does put more drag on the engine and gas mileage. However, I think there might be some benefit to running the A/C a lot more often - it keeps the hoses, seals, etc., used to operating regularly and properly lubricated inside. As a result, you don't have a sudden problem with the A/C not working on a warm day after it's been turned off for 5 months.
colfax
Nov 11, 2018 01:42 PM
blue2
14
Feb 22, 2018 08:05 AM
MikeP
Jul 6, 2010 03:19 PM
worker
Sep 30, 2009 01:44 PM
Lexus88
Dec 19, 2007 01:48 PM
