USB problem
Old Sep 7, 2017 | 02:55 AM
sheri1's Avatar
sheri1
Default USB problem
I play my music through the stereo from a memory stick. Works fine apart from it often reverts back to the first song on the list as opposed to carrying on from where I left off after the ignition is switched off and back on again. Can anyone help with a solution for this?
Old Sep 7, 2017 | 08:49 AM
otakusan's Avatar
otakusan
when the car first starts, the media player has does a scan through the USB drive for all it's contents. So depending on how you saved your music on your USB drive, it may act differently. I've done a few tests on this:
- if you have multiple folders with a number of music files in each folder, when you first start the car, it will play the first song from the last folder it left off before you shut the car off
- if you have multiple music files stored all on the USB drive with no folders, it often will start playing from the first song.
- BUT the above isn't always the case, there are times where it would pick up from partial way into the last played song and continue on normally.
It's a very common thing for any stereo with USB support
waddoguy
Oct 4, 2024 10:16 PM
dingles
Hybrid Technology
Oct 24, 2018 12:48 PM
DBCOM
NX - 1st Gen (2015-2021)
Oct 27, 2016 09:30 PM
DerekGordo
Jul 28, 2016 08:54 PM
gfitz2010
RX - 3rd Gen (2010-2015)
Jan 8, 2011 07:10 AM
