*Time sensitive* Will it rub?
Old Jun 23, 2017 | 06:02 PM
nonopeno's Avatar
nonopeno
Default *Time sensitive* Will it rub?
Hello all,
I have a 2014 IS350 AWD lowered with RSR Coils. Saw a set of second hand Vossen CVT 19x8.5 ET32 for sale, with 235/55/19 235/35/19 Michelin Pilot Super sport tires.
Can anyone please let me know if it will rub with this setup?
Thanks!
Old Jun 23, 2017 | 06:16 PM
NotLucas's Avatar
NotLucas
235/55/19 on all four? Regardless its an uncommon tire tbh. Look at the build and wheel threads to see if anyone else is running that
Old Jun 23, 2017 | 06:31 PM
nonopeno's Avatar
nonopeno
Thanks for questioning the tire size Notlucas - confirmed with seller it was an error and it is 235/35/19. Will continue my search on the forums.
Old Jun 23, 2017 | 07:21 PM
NotLucas's Avatar
NotLucas
235/35/19 should be fine for the front, think it would be a bit skinny for the rears due to 235.
Not sure how a 35 tire wall would fit on the rear, I myself am trying to figure that one out as well
Old Jun 23, 2017 | 07:46 PM
nonopeno's Avatar
nonopeno
The setup is going to be squared 19x8.5 - can you elaborate on what you mean by rear might be too skinny?
Old Jun 23, 2017 | 08:03 PM
Sasnuke's Avatar
Sasnuke
That rim/tire combo is pretty common for a front wheel setup on the IS, if you had staggered wheels. The fact that it is a square setup, you'll be fine.
If they were +35 you would be ok at any height...with the +32, just make sure you're not riding too low.
Old Jun 23, 2017 | 08:09 PM
nonopeno's Avatar
nonopeno
Thanks Sasnuke. Do you mean +32 will rub in the front or back (or both?) if too low?
I am aiming for 1-1.25 inch drop around all 4 corners. Not sure if you would know - is this too low to rub on +32 in your mind?
Old Jun 23, 2017 | 08:17 PM
Sasnuke's Avatar
Sasnuke
Check my signature below...I'm lowered on RSR Downs, which is pretty close to what you are lowering yours to.
I also have 8.5 rims with +35 offset...in normal driving and cornering there's no rubbing at all.
On full lock turns the front tire rub on the inside...on the brake duct vents. Realistically it's no an issue cause how often due you drive at full lock.
With the +32 it brings the rim closer to the fender, at 1-1.25 inches lowered, you should clear the fender during normal driving.
When the tires wear out, I would suggest going to a 225/35/19 if you can. That is actually closer to the factory circumference...almost exactly the same.
Old Jun 23, 2017 | 08:31 PM
nonopeno's Avatar
nonopeno
Thanks Sasnuke. Much appreciated. I will post pics of the setup if I do pick up the set.
Old Jun 24, 2017 | 12:44 AM
zhifan1's Avatar
zhifan1
Hello all,
Thanks!
Im pretty sure with the lowered RSR coils, tyres will rub on the fender lining when turning full lock.
Old Jun 24, 2017 | 08:41 PM
dnasians's Avatar
dnasians
you're fine. those specs will work
ArmaEdd
Jun 20, 2018 07:28 PM
nMeOnE
Jan 31, 2010 08:53 PM
MAS
VIP Style
Sep 4, 2008 04:57 PM
VIP12
IS - 1st Gen (2001-2005)
Mar 3, 2005 05:45 PM
