5 k oil change
Old Apr 30, 2017 | 06:58 PM
ttsport15's Avatar
ttsport15
Question 5 k oil change
I feel like I should just do the oil change myself I saw a diy but not for a 17 any changes? I do all my own anyway and I really want this oil out it basically the break in oil ..
Old Apr 30, 2017 | 07:35 PM
E46CT's Avatar
E46CT
just do it at 10k. it's more than fine.
pretty sure there's no break in oil. this isn't an exotic. just regular old toyota synth
Old Apr 30, 2017 | 07:38 PM
ttsport15's Avatar
ttsport15
I hear ya but I've been driving it hard...Well you know those 4 cylinder altimas can give you a run for your $$ lmao...
Old Apr 30, 2017 | 07:44 PM
E46CT's Avatar
E46CT
If you're driving it hard, 7500 would be reasonable. 5k still too soon.
BMW owners get blackstone lab reports done on their oil and at 15k, Blackstone says the oil and filtration still looks great. Modern oils are really good.
I think 10k is a happy medium, even if driven hard. Up to you though!
Old Apr 30, 2017 | 08:54 PM
Tvue83's Avatar
Tvue83
I was just about to post a thread about this. My maintenance light came on at 5k. Should I even worry about bringing it in? Its free of course.
Old Apr 30, 2017 | 09:24 PM
ttsport15's Avatar
ttsport15
mine too I thought it was a little early
Old Apr 30, 2017 | 09:35 PM
pnoygil's Avatar
pnoygil
I believe it should be 5,000 miles/6 months whichever come first for tire rotation or 10,000 miles/year whichever come first for oil change per manual..
but in my opinion 5000/6 months whichever come first...
Old Apr 30, 2017 | 10:30 PM
premier3IS's Avatar
premier3IS
My 5k light came on around 4850 miles. Took in it last week for the 5k service. There was nothing really to it, they just made sure the cars running fine. Below is what they did according to the dealership:
• Rotate tires and adjust tire pressures as required
• Reset maintenance reminder light
• Road-test vehicle
• Check installation of driver's floor mat
• Inspect and adjust all fluid levels
• Program Lexus Personalized Settings*, if requested
• Visually inspect brake pads, calipers and rotors
Was basically everything you can do yourself at home. Just a hassle going in and wasting a few hours for them to get the vehicle back to you.
Old Apr 30, 2017 | 10:42 PM
evident's Avatar
evident
I just changed my oil at the 35k mark, 5k total on the oil, but it's going to be sitting for a few months only being driven occasionally
Old May 1, 2017 | 05:21 AM
ttsport15's Avatar
ttsport15
• Road-test vehicle
Check installation of driver's floor mat.
Wow that's a new one...
Old May 1, 2017 | 07:10 AM
Sheddy's Avatar
Sheddy
The dealer doesn't change the oil at the 5000 mile check up. I do my own oil changes at 6000.
Old May 1, 2017 | 07:41 AM
JDR76's Avatar
JDR76
Every Toyota and Lexus service includes this ever since the "stuck accelerator" debacle.
Old May 1, 2017 | 08:39 AM
ssmoked's Avatar
ssmoked
I would change it. Toyota doesn't consider the IS250/350 performance oriented and driven hard daily by most owners, so 10k with synthetic is enough. But if its consistently being red lined, it will cause faster degradation of oil. Check the color of the oil, change it if its dark.
I drive all my cars like i stole it daily, so the oil is very brown by 5k. Never hurt to change it early
Old May 1, 2017 | 08:47 AM
ttsport15's Avatar
ttsport15
This is what I figured I'm not going to let them do it and have the car all day ...I'm also doing drill/slotted rotors and pads at the same time
Old May 1, 2017 | 08:53 AM
danthedj's Avatar
danthedj
This would be true in the 70s and 80s as told by some old guy who's "been around the block". Oil color is not an indicator of wear/end of life. The only true indicator is to have an oil analysis performed by a lab like Blackstone. Definitely doesn't hurt to change it early, other than spending 2x what you need to for absolutely no reason. To each their own.
