19x9.5 fitment question
Old 11-11-16, 07:07 PM
KAHK
KAHK's Avatar
Default 19x9.5 fitment question
Hi CL members.
I just got my CPO 2014 IS 250 RWD F-Sport 2 months ago and now looking for new wheels.
I am looking at 19x9.5 ET43 all around, with 255/35/R19 tires. Planning to have a 5mm spacer if it will help. Car is at stock height now.
I am wondering if this set up would fit in my car? Have anyone run this set up before? Would it rub?
Sorry for the noob question. I tried researching but couldn't find a definite answer, so hopefully I could get some answer from you guys. Thanks!
Old 11-12-16, 01:36 AM
sandiegoer
sandiegoer's Avatar
im running 19x8.5 front 19x10 rear on f sport lowering spring. no rub
Old 11-14-16, 10:14 PM
hovik92
hovik92's Avatar
I have 19X9 in the front and 19X10.5 with 235/35 and 275/30 and RSR Down Springs and have no rubbing. I used to have 245/35 on the front tires and had to roll my fenders because it rubbed. My RSR Downs actually sit a lot lower than any other RSR Down springs I've seen and I still don't rub anymore.
Old 11-14-16, 10:30 PM
l33ks
l33ks's Avatar
wheel offsets?
Old 11-15-16, 12:08 AM
KAHK
KAHK's Avatar
Thanks for all the replies. The reason I asked is because I am looking at a set of TE37 which is 19x9.5. I always like the look of it. I am pretty sure it will fit the rear, but looks like the front might not fit without modification...
Old 11-15-16, 06:58 AM
cbus
cbus's Avatar
9.5 in the front sounds like it would be difficult to make work. Widest I've seen on the front here is a 9.
Old 11-15-16, 04:13 PM
hovik92
hovik92's Avatar
Originally Posted by Kendyli
wheel offsets?
+35 Front
+38 Rear
Old 11-15-16, 04:29 PM
Blexxi
Blexxi's Avatar
hello everyone. im new to this forum and also need some help.i just purchased a 2016 350 f sport awd. looking for winter wheels and wanted to know if this would fit with stock height. mainly concerned with front fitment
17x9" +35 or +25 offset.
Also what tire size should i be looking for. i know the dealership and tirerack suggest 225 45 17 all 4 corners.
thanks for any info provided.
Old 11-15-16, 09:25 PM
l33ks
l33ks's Avatar
+35 Front
+38 Rear
Thanks! I'm on Swift springs which is about the same drop so I should have no problem with that setup too.. there's no rubbing even with a full car?
5nX37
Suspension and Brakes
07-01-15 11:55 AM
MileHIFcar
IS F (2008-2014)
20
06-20-15 10:56 AM
AZGHOST
10-31-13 11:09 PM
ktb
IS F (2008-2014)
12
01-30-13 05:23 PM
IS350HKS
11-06-10 03:49 PM
Quick Reply: 19x9.5 fitment question
