Leaving accessory power on after turning off engine
Old 11-08-16, 09:20 PM
srv777
srv777's Avatar
Default Leaving accessory power on after turning off engine
Is there a way to leave the accessory power after turning off the engine when you are parked? I found 2 ways from reading the forums:
1. Turn off the engine then press power button again
2. Put car in neutral, then turn engine off, then put car in Park
Both steps require multiple steps. Is there a shortcut?
With my last car, which was an Acura TL, you can park car, then press the shifter button, while stepping once brake pedal and then shutting the engine off to leave the car in accessory mode all in 1 step.
Old 11-09-16, 03:51 AM
brendanf
brendanf's Avatar
As far as I know the only way are the 2 you listed, and they have 1 problem. After about 20 mins the car will turn off the accessory to save power.
The only to stop it is to keep it in neutral.
I set my parking brake, shift to neutral, and then stop the engine and leave it like that until I am ready to leave the car or continue driving it.
Old 11-09-16, 05:19 AM
genmaster
genmaster's Avatar
any idea how long I can run say the ML audio in this mode without having to worry about draining the battery too much?
Old 11-09-16, 08:37 AM
brendanf
brendanf's Avatar
I have no idea. Perhaps someone else might know.
Old 11-09-16, 09:08 AM
Break2
Break2's Avatar
I've been trying to figure this out too.
Old 11-09-16, 11:46 AM
Jlin89
Jlin89's Avatar
8 hours before you have to charge your battery
Old 11-09-16, 01:55 PM
Jackal84
Jackal84's Avatar
I wish there was an easier way, took me a while to even figure that way out. I can't believe they just don't have an accessory mode button or button sequence
Old 11-09-16, 05:14 PM
srv777
srv777's Avatar
Ok thanks all for confirming that those are the sequences that work and no others exist. Guess I will have to live with the convoluted way!
elbarto
11-22-22 02:13 PM
fiddler1
ES - 6th Gen (2013-2018)
10-01-17 09:29 AM
typocl
NX - 1st Gen (2015-2021)
03-18-15 03:15 PM
Lexobu
ES - 5th Gen (2007-2012)
03-16-15 09:00 PM
swisslexusclub
02-10-06 02:49 PM
Quick Reply: Leaving accessory power on after turning off engine
