LED interior? Help
Old Feb 19, 2016 | 10:46 PM
jd93's Avatar
jd93
Default LED interior? Help
I am looking to switch all interior lights, trunk light, and mirror puddle lights to LED.
I am aware I need 194 style led bulbs and I plan on getting them from VLEDs as I have their reverse LEDS and they look great.
So in total I believe I will need:
3x front dome
3x rear dome
2x footwell
2x sunshade
2x mirror puddle lights
1x trunk
=13 style 194 LEDS
My question is does anyone know the best type of 194 to get for each application? For example VLEDs carries different configurations (see picture attached) I believe I read somewhere the puddle lights would work best with flank style bulbs? Not sure about the rest of the interior any opinions? Thanks
Old Feb 20, 2016 | 06:54 AM
39RN's Avatar
39RN
Start here. this discussion may help with your research.
https://www.clublexus.com/forums/is-...han-stock.html
Old Feb 21, 2016 | 09:19 AM
jd93's Avatar
jd93
Didn't help i already know which company LED's I will purchase I'm looking more for the application of each bulb and how they sit in their respective housings
Old Feb 21, 2016 | 10:55 AM
J3ffrey's Avatar
J3ffrey
pull em out, put em back in, it's that simple.
Old Feb 21, 2016 | 12:22 PM
typocl's Avatar
typocl
and if they don't work, pull those out, flip them, put em back in
footwell bulbs are a pain to remove though
Old Feb 22, 2016 | 06:15 AM
TaninAuto's Avatar
TaninAuto
Sponsor
3x front dome
3x rear dome
2x footwell
2x sunshade
1x trunk
=13 style 194 LEDS
Hi, Tanin Auto Electronix here. We are vendors on the site and we can help you if you need to purchase the 194 LED once you determine which sizes you need. Here is a link to our options available on our website:
http://www.taninautoelectronix.com/S...asp?Search=194
Let us know if you have any other questions on this. We are always happy to help! If you are already set on where to get them, no worries. Just wanted to offer some options!
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
https://taninjdm.com/
Our Lexus LS430 Dealership
Old Feb 22, 2016 | 12:15 PM
harkirath's Avatar
harkirath
Do 2015 350 F Sports even have trunk lights? Mine has never lit up if there is one present. Where is the bracket?
Old Feb 22, 2016 | 12:44 PM
jd93's Avatar
jd93
Yes, open the trunk at night it should light up, the bulb is located in the upper middle of the trunk
Old Feb 22, 2016 | 02:27 PM
harkirath's Avatar
harkirath
Need to look into this then. Definitely nothing lighting up in my trunk.
Old Feb 22, 2016 | 09:25 PM
chyeea03's Avatar
chyeea03
I think the best ones for each are flank in the courtesy, puddle, trunk and footwell lights and 360 in all the bulbs in the overhead. You can always just pop off the covers and check for yourself if you already have the car.
Old Feb 22, 2016 | 09:40 PM
jd93's Avatar
jd93
Thanks, someone who actually understood the question. I did end up removing all the covers to see which bulbs would work best. Thanks though!
Old Feb 22, 2016 | 10:04 PM
chyeea03's Avatar
chyeea03
Wanna confirm which ones are best for each position for anyone doing a search in the future?
Old Feb 22, 2016 | 10:37 PM
jd93's Avatar
jd93
Yes I will.
These applications will work best (although it is possible to use 360 style bulbs for all of them, they cost more and don't project the light accordingly)
Front dome- 3x straight down bulbs (or 360 but I think the straight bulbs will project light better)
Rear dome- 3x straight down bulbs (or 360 same as above^)
Footwell- 2x straight down bulbs (1 on each side sit vertically)
Visor mirrors- 2x flank (bulb sits horizontally)
Mirror puddle lights- 2x flank
Door panel lights- 2x flank
Trunk- 1x flank bulb (bulb sits horizontally)
Old Feb 22, 2016 | 11:25 PM
LeeJonah's Avatar
LeeJonah
Anyone know why my 3is have no footwell lights? Or does it just turn off when I'm driving?
Cause my friends 2is have footwell lights lit even when driving
Old Feb 22, 2016 | 11:26 PM
jd93's Avatar
jd93
They illuminate when the door is open and will fade off when the door is closed
