How do I clean this ??
Old Jan 18, 2016 | 07:48 PM
jeeper2269's Avatar
jeeper2269
Default How do I clean this ??
Spilled pre-workout on the driver's side rear door speaker. As you can see, it's all white. How would you suggest to clean?
Old Jan 18, 2016 | 08:00 PM
EZZ's Avatar
EZZ
Magic eraser.
Old Jan 18, 2016 | 08:11 PM
EdoApero's Avatar
EdoApero
the magic of pre-workout
Old Jan 18, 2016 | 08:27 PM
iSuxeL's Avatar
iSuxeL
Take off the door panel and spray it from inside out with probably just water or you can use a brush to agitate it
Old Jan 18, 2016 | 08:28 PM
BostonIS's Avatar
BostonIS
Hand vacuum? If its just the powder the vacuum should suck it all up. Lol this will be a reminder to me to not mix supplements in my car although I do it quite often.
Old Jan 19, 2016 | 01:50 AM
isfdude's Avatar
isfdude
I would use windex and spray the windex on the micro fiber rag so you don't wet the speaker and use a tooth brush or vacuum bristle head. Worked for me but took a little bit of time.
Old Jan 19, 2016 | 05:59 AM
goldengame's Avatar
goldengame
Have you tried just wiping it with a damp microfiber cloth? That takes out 95% of things in my car, and especially works well on the hard plastic pieces.
Old Jan 19, 2016 | 06:30 AM
woowoo's Avatar
woowoo
Suck it up!!!!!
With a vacum
Old Jan 19, 2016 | 09:25 AM
dnasians's Avatar
dnasians
please do not use any water or liquid cleaner! it will turn that powder supplement into gunk!!! vacuum it away. if you have the carpet brush vacuum attachment, that will work best
Old Jan 19, 2016 | 09:39 AM
Jbreezie's Avatar
Jbreezie
U sure it wasn't Coke? Haha I spilled pwo many times in my car. I usually have meguiars quick detailer wipes on hand. A strong vaccumm should be able to get it if not. Last resort would be an all purpose cleaner. Check out detailed image.com for detailing supplies. We also have a detailing section here.
Old Jan 19, 2016 | 10:28 AM
sdotk's Avatar
sdotk
I imagine a toothbrush would work quite well.
Old Jan 19, 2016 | 11:09 AM
dfwjohnd's Avatar
dfwjohnd
Originally Posted by Jbreezie
U sure it wasn't Coke? .
hahaha yes
Old Jan 19, 2016 | 12:30 PM
Luisvm's Avatar
Luisvm
I second this if the hand vacuum doesn't work. The door panel is really easy to remove. It's only a few screws and a handful of plastic clips, but you do have to use a plastic pry tool to pop off the plastic screw cover by the inside door handle. Also, be prepared to unplug two cables once the door panel is off to allow you to fully detach it from the car.
Old Jan 19, 2016 | 01:35 PM
woowoo's Avatar
woowoo
Bro jizzed on his car because it's too sexy...
I don't blame you!!
MGB1120
Sep 3, 2014 08:44 PM
doverrx330
Apr 27, 2013 06:05 AM
-Future-
Automotive Care & Detailing
May 23, 2008 02:10 PM
TheSyndica
Mar 19, 2007 11:55 PM
TwentyTen
Apr 30, 2005 02:39 PM
