LED turn signal question
Old Nov 22, 2015 | 09:54 PM
Cconnors09's Avatar
Cconnors09
Default LED turn signal question
I was looking to swap my turn signals to LED ones. I don't feel comfortable with the idea of splicing and stuff. I was wondering if anyone has used these ijdmtoy ones that are plug and play with built in decoders and if so, how they looked. Or if you swapped to led but didn't use these specific ones and did not have to splice (plug and play adapter of some sort) if you could share as well..
Heres the ones from ijdmtoy. I've purchased LEDs from them in the past and have no complaints but I've never tried these. Thanks!
http://store.ijdmtoy.com/Error-Free-...m?CartID=1#des
Old Nov 22, 2015 | 11:27 PM
LINSTEFAN's Avatar
LINSTEFAN
Old Nov 23, 2015 | 06:09 AM
KYLESTONES's Avatar
KYLESTONES
I like them, especially in white.. Although not legal
Old Nov 23, 2015 | 01:46 PM
plastus's Avatar
plastus
Make sure the decoders have appropriate fittings for the IS housings. I purchased a set of LED bulbs and adapters from a vendor on here. The adapters fit the rear sockets no problem, but the fronts required some modification using a Dremel because the notches were not the right height/width.
Old Nov 23, 2015 | 03:04 PM
KYLESTONES's Avatar
KYLESTONES
On their website it says tested on a 2014 3is, so hopefully they're plug and play with no modification
Old Nov 23, 2015 | 06:51 PM
Carbonite's Avatar
Carbonite
I have them. I purchased them to get rid of the "egg yolk" look that amber bulbs give off.
The only downside I'd mention is that the bulbs use rubber "boots" around the lamp that hold them into the housing, instead of a plastic socket that twists into place. They hold tightly into place once they're inserted but I found it difficult to get them pressed into place without first adhering the boot to the bulb with a little permatex ultra gray I had on hand. Otherwise the bulbs kinda moved around inside the boot making it hard to press them into place properly.
Also, polarization is important and they can be plugged in "backwards" that is to say if they are, they won't work at all. A quick 180 on the plug is the solution in this case,
Last, I'd say that the video is an accurate representation of them in action.
Old Nov 23, 2015 | 08:04 PM
DjRiDe's Avatar
DjRiDe
i have a set of amber in my car and no complaints at all!
Old Nov 23, 2015 | 08:06 PM
Cconnors09's Avatar
Cconnors09
How's the install on both rear and front? The driver side front seems like it could be very frustrating. And the rears I would assume you take off those screws that attach the lining and just work in there?
Old Nov 24, 2015 | 07:16 AM
J3ffrey's Avatar
J3ffrey
Anyone have any other options to change over to LED? the first thing I'll be doing is swapping all bulbs to led... no idea why they don't do this from the factory
Old Nov 27, 2015 | 04:49 AM
KYLESTONES's Avatar
KYLESTONES
Actually decided to buy a set (in white).. Will post pics/vid once installed
Old Dec 1, 2015 | 02:49 PM
J3ffrey's Avatar
J3ffrey
Ready to order, 80 is a bit steep, anyone have a coupon code?
Old Dec 1, 2015 | 03:26 PM
KYLESTONES's Avatar
KYLESTONES
Haven't been able to take a video but I can say that these are high quality and bright. Very clear color. Looks great.
Old Dec 1, 2015 | 05:12 PM
J3ffrey's Avatar
J3ffrey
no CL discount?
Old Dec 1, 2015 | 05:44 PM
KYLESTONES's Avatar
KYLESTONES
Originally Posted by J3ffrey
no CL discount?
None that I know of, didn't really check either since it wasn't all that expensive for the 1 set
Old Dec 1, 2015 | 06:31 PM
J3ffrey's Avatar
J3ffrey
You replaced just the fronts? Why not the backs?
