Do i need gaskets?
Old Oct 15, 2015 | 10:08 AM
LeeJonah's Avatar
LeeJonah
Default Do i need gaskets?
Hi, for everyone who installed the JoeZ axle back exhaust onto the RWD 3is, I was wondering if you needed to use gaskets. I recent purchased a used axle back and the seller told me that gaskets were not needed and to directly screw the exhaust onto the factory mid pipe.
Any help would be great!
Thanks
Old Oct 15, 2015 | 10:15 AM
cp2's Avatar
cp2
Veteran: Air Force
umm...yes. having them will help if you have an exh leak
Old Oct 15, 2015 | 10:23 AM
LeeJonah's Avatar
LeeJonah
So should I reuse the factory gaskets because I was not provided with any gaskets when I bought the exhaust?
Old Oct 15, 2015 | 10:31 AM
techrep's Avatar
techrep
if it's in good shape...sure
Old Oct 15, 2015 | 11:05 AM
Snowrydr01's Avatar
Snowrydr01
I just put mine on yesterday morning and you re-use the little cone shaped gaskets.
Make sure you have the bolts if you bought it used since it doesn't re-use the stock hardware.
Also, if you do not that a 14 and 15 mm ratcheting wrench you are going to HATE the install. the top side bolt on each side only turns about an 1/8 of a turn at most before you contact something. You also cant get and impact on them because of the angel.
Total install time was 40 minutes from getting the car up on ramps to putting the cleaned tools away.
If you haven't fought with exhaust hangers use a pick of something on the outside so as you push against the backside of the hanger it slides over the hump on the exhaust more easily
Old Oct 15, 2015 | 11:21 AM
LeeJonah's Avatar
LeeJonah
Luckily i do have the included bolts! Thanks for all the advice!
Old Oct 15, 2015 | 12:30 PM
Snowrydr01's Avatar
Snowrydr01
i forgot to mention depending on the ramps used you might have to offset them to the outside a little AND use a 2x8 as a pre ramp. My ramps were so tall they would hit the bumper first so i used a 10" long 2x8 and that was fine but when they were centered to the tires then the hit the stock exhuast.
Also, if you havent dont exhuast before get a bungee cord and hand it by the connectors as a dummy set of hands
Order of process that always works for me is:
Break bolts lose but leave on.
Get the rubber hangers over the humps but leave on.
remove of of the two bolts
remove the horizontal hanger
remove the other bolt to now lower the exhuast (now resting on your bungee or strap)
slide the exhaust forward and off of the two rear hangers
Old Oct 15, 2015 | 01:52 PM
Sexis350's Avatar
Sexis350
Any drone jonah?
Old Oct 15, 2015 | 02:02 PM
LeeJonah's Avatar
LeeJonah
Originally Posted by Sexis350
Any drone jonah?
Have no installed it yet because my car is in the shop for repairs
Old Oct 15, 2015 | 03:42 PM
chyeea03's Avatar
chyeea03
Great to hear you finally got your exhaust! Definitely update us on how you like it once you put it in.
Old Oct 19, 2015 | 01:17 PM
dnasians's Avatar
dnasians
the thing with gaskets is that they tell you to use new ones every time you have to uninstall parts of the exhaust. do you have to? no. should you? probably. it's a cheap disposable piece that when you're down there and everything is opened up, you might as well change them out.
you can think of this similar to when you change an alternator or water pump,. you might as well change out the serpentine belt while you're there
JonHT
Mar 23, 2020 05:44 PM
huskyfan23
RC F (2015-present)
Jan 9, 2017 01:00 PM
jhardy
Nov 11, 2016 11:10 AM
BrittonJ85
15
May 26, 2010 03:46 PM
cw04
IS - 1st Gen (2001-2005)
Feb 23, 2004 10:33 PM
