Vgrs
Old Aug 29, 2013 | 06:09 PM
GriffinCO's Avatar
GriffinCO
Default Vgrs
Hey All,
The dealer says I can order the VGRS option with the regular IS 350.
What exactly does it do for the car's performance?
Cheers!
Jamie
Old Aug 29, 2013 | 06:59 PM
4TehNguyen's Avatar
4TehNguyen
http://www.caranddriver.com/features...eering-feature
Prime Cuts: Lexus Variable Gear Ratio Steering
We slice open the activist of active systems.
FEBRUARY 2012 BY TONY QUIROGA
The ability to change a vehicle’s steering ratio has many advantages. A quicker ratio (fewer turns lock-to-lock) can give a vehicle a deft feel. At high speeds, switching to a slower ratio (more turns lock-to-lock) imparts a better sense of stability. Lexus is not alone in using a computer-controlled system to change ratios, but its approach is pretty trick. Note that this type of active steering is far more involved than the variable-ratio units with rack teeth cut at differing angles; they can’t make ratio changes on the fly over the full range of lock. The more complex Lexus (and Audi) approach is essentially a gearbox built into the steering column between the steering wheel and the pinion gear. Unlike BMW’s active steering system, which employs a planetary gearbox, Lexus’s Variable Gear Ratio Steering (VGRS) uses something called a wave generator and a flexible gear. Lexus claims its system is more accurate and quicker acting than others. VGRS can be found on the LS sedan, the LX SUV, and the new GS F Sport. We sliced into the unit to get an idea of  how it works and because we wanted to find out what a wave generator is.
Old Aug 29, 2013 | 11:06 PM
azmojo's Avatar
azmojo
Your dealer doesn't know what he's talking about, or the lexus website is wrong:
http://www.lexus.com/models/IS/features/
Old Aug 30, 2013 | 03:16 AM
GriffinCO's Avatar
GriffinCO
Yeah, I thought the same thing when I heard it. But I've had confirmation from more than one dealer that they could add it to the order (after doing some research on it themselves.)
Old Aug 30, 2013 | 06:02 AM
yycdave's Avatar
yycdave
Anyone know if VGRS is available in Canada? I can't find references to it anywhere.
Old Sep 9, 2013 | 06:56 AM
internalau's Avatar
internalau
I believe the the 350 RWD F-sport and RWD F-sport premium have the VGRS and AVS.
Old Sep 9, 2013 | 12:01 PM
SimTide985's Avatar
SimTide985
Actually, the VGRS isn't inherently part of the F-Sport model. It's only part of a particular package as an add-on.
Old Sep 9, 2013 | 01:48 PM
internalau's Avatar
internalau
Damn Lexus Canada. I was told (here on this forum) that where I live, we cannot include any add-on and will have to stick with the option packages.
I'll probably wait for the mid-cycle refresh anyway but good to know many Lexus owners are quite helpful to fellow owners/prospective buyers.
Old Sep 9, 2013 | 01:50 PM
SimTide985's Avatar
SimTide985
You see, I can only speak for how it is here in the US. In Canada, it could be quite different---so you might want to check with your dealer to make sure.
Old Sep 9, 2013 | 02:07 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Lexus Canada doesn't really do individual factory options, you have to get packages up here.
Jeff
prwdmd
Hybrid Technology
Apr 13, 2016 01:51 PM
mocca
Dec 11, 2015 01:01 AM
DMPesso
Mar 24, 2013 12:49 AM
natnut
Apr 26, 2012 05:35 PM
g-force
Suspension and Brakes
Mar 7, 2002 11:41 AM
