I have a 2021 is350 f sport and when I went in for an alignment they told me the right rear toe adjustment is seized up. I want to try and replace it myself, I was seeing if anyone has any suggestions for brands or tips on replacing? Thank you for your help!
You can spray penetration oil over every night for few nights. Then pray it will work to lube it loose. Otherwise you’ll have to cut the bolt . I just stick with oem nuts, bolts and arms. Just add anti seize when putting it back together. You can find used ones.
I had trouble finding parts online, the only brand I saw for an awd was Godspeed. To get an oem part should I go to the dealer and ask for one or what is the best way? I’m going to look for the toe arm today and see if I can turn it myself.
Stick with oem if you have to cut it out. Yes can be bought at your local Lexus dealer or online if you know part number. But if you able to break it lose and taken apart just put anti seize for the further.
