2016 IS300 front differential
Old Aug 16, 2025 | 08:16 PM
laobo979's Avatar
laobo979
Default 2016 IS300 front differential
Guy I change my front diff before got it to loosen easy. Second time around not so much. I had luck with 50 degree wrench but now it won't work with little to no room to turn. Has any one have a good tool they used for it. I also used a long extension wrench. Just wanna hear what worked for you to decide what I can do thanks.
Old Aug 21, 2025 | 10:35 AM
jinseug's Avatar
jinseug
The front fill plug is a pain in the butt.
I bought an offset wrench for this job, but it didn't work for me. Luckily, the Dewalt combination wrench that I use for the engine oil plug did. It has a slight bend at the closed end. I've done it twice so far, and it worked both times. Hope it works for you too.
Old Aug 21, 2025 | 10:39 AM
jinseug's Avatar
jinseug
This is the link for the exact same one I bought from amazon.
Amazon Amazon
Old Aug 22, 2025 | 06:34 PM
laobo979's Avatar
laobo979
Yeah I have a wrench like that but just as soon as I put it on it hit the are that sticking out. So no room to make a turn. I might take to a shop and let them deal with it for now.
Old Aug 23, 2025 | 02:56 PM
jinseug's Avatar
jinseug
Perhaps an offset extension wrench paired with a stubby socket could do the trick?? I think this would be my last resort before taking it to a shop.
Old Aug 23, 2025 | 04:22 PM
kj07xk's Avatar
kj07xk
https://www.amazon.com/dp/B019YWTIUM...d_asin_title_2
Weird. I used that link and ordered one, but they shipped the wrong item, they shipped a DWMT723020SP, which has a ratcheting end that is not angled. Set up a return for the wrong item sent, and had them ship another, which also arrived as the wrong item. Started a return for it also. The seller apparently doesn’t stock the angled end wrench anymore, and ships something else.
Old Aug 25, 2025 | 10:20 AM
jinseug's Avatar
jinseug
What a hassle...
It looks like Ace Hardware has the same wrench on its website. The model number is DWMT72215.
https://www.acehardware.com/departme...m4MPhAxgQvtXok
I took out my own wrench to confirm the model number. Hope this wrench will work for you.
KPCresta
IS - 1st Gen (2001-2005)
Sep 6, 2020 12:24 PM
over40driv
Jun 11, 2010 03:41 PM
ahhyes300
Nov 14, 2008 01:51 PM
usi4mi
13
Aug 22, 2006 12:46 PM
