AC vent mounted cellphone holders - DON’T DO IT!!
Old Feb 23, 2025 | 12:23 PM
GS350TKM's Avatar
GS350TKM
Default AC vent mounted cellphone holders - DON’T DO IT!!
The AC vents were not meant to hold any sort of pressure whether it be from the phone or the ratcheting part of the mount, or both.
When it breaks, which it will, the vent is part of a larger piece that runs about $280.
The replacement is a pain in the *** as well. We just did this replacement for a customer.
Old Feb 23, 2025 | 04:04 PM
InveredMP's Avatar
InveredMP
I literally broke mine
That vent assembly just pulls straight out, doesn't it?
Do you have that PN?
Old Feb 24, 2025 | 02:21 AM
GS350TKM's Avatar
GS350TKM
You'd think so. The bezel around the driver gauge cluster needs to come off first since that overlaps the bezel on the left side.
Then loosen the screws to the top most portion of the center console just under the vents. The vent bezel should be able to pull out. The clock can be disconnected and later removed from the bezel. It was a pain to get the new one in since the bottom of the bezel is just a tiny bit tucked under the top part of the center console. You'd think the thing would just come straight out but it doesn't.
PN I'd have to double check. Its on the part in my photos but I forgot which of the PN's shown was the one for the entire piece. Lexus told us it only comes as a complete piece. smh
Old Feb 24, 2025 | 06:32 AM
InveredMP's Avatar
InveredMP
I have to order one for mine so if you find the correct PN I would appreciate it, as mine is the same color. I kid you not, I bought my car, finished the paperwork, got inside, mounte my phone with the same holder I used in my 2019, and broke the vent within minutes of ownership lol.
Old Feb 24, 2025 | 06:33 AM
Bearcats98's Avatar
Bearcats98
I appreciate this response. This give me a better idea how I need to disassemble my stuff. Thanks for the info!
Old Feb 24, 2025 | 06:48 AM
InveredMP's Avatar
InveredMP
Found the PN for those that need it: 55670-53220-C0
Old Feb 24, 2025 | 06:04 PM
GS350TKM's Avatar
GS350TKM
PN I had for the black one in the photos was55670-53220-C0
Old Feb 24, 2025 | 06:07 PM
InveredMP's Avatar
InveredMP
Yep, found it and posted it above.
Old Feb 27, 2025 | 05:05 AM
SlowlaneAZ's Avatar
SlowlaneAZ
I never understood why vent mounts are so popular. For this reason and you block an air vent.
I get there aren't many options for the IS, but this is worst of what's available.
Old Feb 27, 2025 | 06:22 AM
InveredMP's Avatar
InveredMP
I used a vent clip on my previous IS and loved it. I barely screw one into this vent and break it lol.
My replacement arrives today.
Old Feb 27, 2025 | 03:45 PM
InveredMP's Avatar
InveredMP
Received my replacement today.
Old Feb 28, 2025 | 07:18 AM
InveredMP's Avatar
InveredMP
I replaced my vent this morning. Took about 20 minutes. Not too bad!
Old Feb 28, 2025 | 12:53 PM
kj07xk's Avatar
kj07xk
Ok, time to crank on the cell phone holder!
Old Mar 1, 2025 | 08:04 PM
Nexus713's Avatar
Nexus713
I have a question - to remove center clock, do I have to remove whole vent assembly as well? I am planning to replace clock with OBD2 gauge that has same diameter (52mm) and put it in place of the clock but i can’t find any instructions online how to remove it.
thanks in advance!
SIKEFrostbite
IS - 1st Gen (2001-2005)
Aug 14, 2024 06:04 PM
eevegas
May 24, 2021 07:13 PM
GFerg
Jun 1, 2007 10:29 PM
LexFather
May 17, 2006 10:39 AM
