I've been noticing a subtle sound like liquid is sloshing around when I get in and out of my 2023 IS 500. Car has about 15,000 miles on it. I've read that this could be a clogged AC drain or a clogged door drain. That seems unlikely due to the mileage of the car, but I'm not ruling it out. Has anyone else experienced something like that?
Can you make the sound by rocking the car? (Use an open door to give you leverage.)
Yes, was just doing this. It seems to be towards the rear of the car, underneath it.
I did a little test drive, and I can see water slowly draining out of the AC drain. Very slowly.
I actually remember hearing this noise.. I thought it was the gas in the gas tank. I was able to reproduce it when the car was in park and moving the car back and forth, no leaking though
You can open the sunroof and pour water in the drains to see if they’re clogged. Run the ac for a while and make sure you see it draining out under the car. You could also potentially have some air pockets in the cooling system
I assume your 500 has the same hidden pockets on either side of the trunk, under floor panels, like on my 350? One side houses the audio amplifier, the other side empty. Water intrusion ends up ruining amps sitting in that pocket. Can’t imagine that enough water could be in there to be heard as sloshing, but worth a check for piece of mind.
