Dash Cam memory card
Old Jul 25, 2024 | 02:01 PM
Lee3333's Avatar
Lee3333
Default Dash Cam memory card
I am trying to find the largest memory card I can use. Lexus says 128GB, but the one I tried didn't work It was a cheap one, though. The 32 GB card I am using is the SanDisk Max Endurance card and made for dash cams. Has anyone used a larger one, and does it need to be high speed? Thanks for the help
Old Aug 14, 2024 | 03:30 PM
Lee3333's Avatar
Lee3333
I spoke to Lexus and they said that 128 gb will work I bought a special high speed one made for dash cams. Does not work The dash cam lights all flash Anyone try a 64 gb memory card?
Old Aug 14, 2024 | 06:38 PM
Rhydg1's Avatar
Rhydg1
Maybe the card need to be formatted to a specific file system? I used a 128GB with my Garmin dashcam hardwired in my IS. Fake SD cards are also a thing to watch out for.
Old Aug 15, 2024 | 08:01 AM
RussellTeo's Avatar
RussellTeo
It's not about size / capacity of the SD card.
it's all about the heat tolerance of the NAND memory cell after repeated read & write.
Go for Samsung High Endurance.
Will last a lifetime (at least >3yrs if you're in AZ).
Rest may last 1-2 years if you park under the sun everyday for >85F / 25C outdoor temp (indoor car cabin will be 1.5 to 2.25x hotter).
Be sure to get dashcam with Cloud auto upload if there's collision or motion detection, cos car burglars will ****** the dashcam to prevent detection.
Best dashcam are 3-channel if you want to record ppl breaking inside your car.
Rear (2-Channel) is perfect for roadrage overtaking, & other vehicles speed estimation based on road sign/landmarks they passed-by, in a certain amount of timestamp.
Amazon Amazon
Old Aug 15, 2024 | 10:32 AM
arentz07's Avatar
arentz07
Yeah I would use the Lexus dashcam app to initiate a format. That should fix the issue. If not, not sure what restrictions there are on which SD cards you can use off-hand, but I believe it is in the user manual for the dashcam.
Geopoz
NX - 2nd Gen (2022-current)
Jan 10, 2024 10:06 AM
Metal1
Nov 18, 2023 05:50 PM
LS500Fan
LS - 5th Gen (2018-present)
Feb 25, 2023 01:49 PM
TheBootLeg
Apr 9, 2022 02:19 PM
johnc22
Jul 16, 2019 03:20 AM
