TPMS issue
Old Dec 7, 2023 | 04:55 PM
kingkuan's Avatar
kingkuan
2nd gear
Default TPMS issue
My IS 200t 2016 TPMS shows "---" on all 4 tires every day morning.
However, if you drive awhile, stop, turn off engine and turn on the engine, the TPMS shows the value.
I replaced the tire in Costco in June which the issue happened after tire replacement.
I check the forum and found some people have the same issue.
My tire pressure warning light is not on.
i follow their instruction and reset the TPMS.
But still have same issue.
i have the following questions:
1. Should I replace the TPMS?
2. when Costco replaces the tires, they charge the TPMS package.
should I go back to COSTCO and ask them the issue or just go to any tire store for replacement of new TPMS if needed?
3. is OE TPMS worth or just purchase aftermarket ones?
thanks you for your help.
Last edited by kingkuan; Dec 7, 2023 at 05:01 PM. Reason: forget to say my car is is 200t 2016
Old Dec 8, 2023 | 12:01 AM
athanato's Avatar
athanato
If you are using the original set the batteries could be low, you can get after market clone-able sets and the programmer for cheap so you don't have to re-program the car with new IDs. see https://www.clublexus.com/forums/is-...l#post11625051
Old Dec 8, 2023 | 06:11 PM
kingkuan's Avatar
kingkuan
2nd gear
so i went to Costco to check the condition since i replaced the tires there.
they check the issues and told me the battery of left rear TPMS is dead.
i change the 4 sensors in Costco,
parts: Dill sensor #1218 4 @ $74
labor: 4 @ $14
i ask Costco to return the ones from the car.
it also shows pacific industrial co. limited on the bottom.
Not sure it is OE or not but i trust Costco and its quality.
when i have an issue, i will just go back to Costco and ask them to repair.
thanks for your help.
Old Dec 10, 2023 | 10:52 AM
lexo98's Avatar
lexo98
labor: 4 @ $14
Pacific makes the sensor. Dill and Denso repackage it and sell it as their own.
amp3d
Feb 4, 2023 03:39 PM
ACP84
NX - 1st Gen (2015-2021)
Nov 7, 2019 10:29 AM
greeknasty
RX - 3rd Gen (2010-2015)
Oct 12, 2016 08:12 AM
babyduke
May 26, 2015 07:34 AM
girvan
Jul 31, 2009 09:34 PM
