2023 IS350 - Window Tint
Old Sep 26, 2023 | 06:06 PM
cerbois's Avatar
cerbois
Is the coating on the rear side windows also???
Old Sep 26, 2023 | 06:45 PM
HeadShot's Avatar
HeadShot
Originally Posted by cerbois
so are you concerned about him scratching the uv factory coating to remove old tint??
No, not concerned at all about him removing the tint. I am concerned how, or if he will correct the issue. If he says he can't get it better ... I need to find an installer that uses llumar tint (to match the other windows). Hopefully, he can work this out.
Old Sep 27, 2023 | 06:18 AM
AkioToyoda4Ever's Avatar
AkioToyoda4Ever
I'm very interested in the steam method you mentioned. I will ask the shop about it...I really need a better tint to survive the Texas summers...
For what its worth my daily driver (Cherokee X) has exactly the same tint imperfection at the passenger's window - I only noticed it a year after the tint was installed. I can't say it bothers me enough to devote time to get it replaced.
Old Sep 27, 2023 | 09:27 AM
HeadShot's Avatar
HeadShot
I understand why he would use steam. You want to gently warm/loosen the adhesive trapped between the tint and the glass. Any remaining residue can then be cleaned.
I will post an update here to share the outcome. Hope it may help someone down the road.
Old Sep 28, 2023 | 04:02 AM
2017FSport's Avatar
2017FSport
I tint for a living, and no that is not "normal". It needs to be redone. Also, as far as I know there is no factory coating on the IS. I had a '21 model that I tinted 3 different times because my wife wanted it darker, didn't run into any issues. The NX has a factory coating I know, because I had one of those as well. Even if he uses steam to remove the old tint, chances are it will leave some glue and still need scraping to get absolutely clean. Except on the rear window, you can't scrape the defrost lines. You have to use steel wool and soapy water to remove any glue. While it is possible to get a perfect job, it is by luck only. No tint job will be absolutely perfect unless you are in an air tight environment with no dust/fiber particles flying around in the air. Can it be better than what is shown here? Absolutely.
Old Sep 28, 2023 | 04:44 AM
HeadShot's Avatar
HeadShot
Thank you for responding. You, along with others here have confirmed my opinion completely. No .. It is not normal, and needs to be redone. If time permits I will see him today. Hopefully, he agrees to redo that window, so I can put it behind me, and move on. Thanks again!
Old Sep 28, 2023 | 09:10 AM
cerbois's Avatar
cerbois
Not sure about the is not having the coating on front sides... Manual says something about cleaning fronts differently. ???
Old Sep 28, 2023 | 10:02 AM
AkioToyoda4Ever
My 23 IS350 has the UV stamp by Lexus on all glass except the windshield.
Good luck Headshot, let us know how it goes...I will visit my shop this weekend and bug them about fixing mine again...
Old Sep 28, 2023 | 11:33 AM
cerbois's Avatar
cerbois
can you take a picture of that when you get time? Thanks.
Old Sep 28, 2023 | 04:11 PM
AkioToyoda4Ever
Old Sep 28, 2023 | 05:02 PM
2017FSport's Avatar
2017FSport
On what years? My '21 didn't have a coating on them. My 2019 NX did. None of the IS models we have tinted have had that coating on them. My Daughter's brand new '23 RC 350 didn't have the coating either, I tinted it today. To my knowledge, and I am not a Lexus expert, but the only vehicle they make that has had the coating is the NX. But our tint cutting system has notes for all of the cars we enter into it, and we get no notifications except when we enter the NX. I could be wrong, but haven't encountered it yet.
Old Sep 28, 2023 | 05:26 PM
cerbois's Avatar
cerbois
IS 2023. warned about using chemicals on front sides in booklet. I have the LEXUS UV label like akiatoyoda4ever.
I ll have to warn my tinter when he re does my 2 windows. ???
Old Sep 28, 2023 | 05:44 PM
2017FSport's Avatar
2017FSport
I know some have the water repelling front door glass, but that is all. Is that possibly what you guys are talking about? Because you wouldn't want to use any chemicals on that. Can ya'll post up the info in the manual? I don't still have our manual to our '21.
Old Sep 28, 2023 | 08:29 PM
HeadShot's Avatar
HeadShot
I think this may be what @cerbois was talking about. At the top of pg 273 re: cleaning.
Old Sep 28, 2023 | 08:50 PM
HeadShot's Avatar
HeadShot
Hey thanks!! I am seeing him tomorrow at 1:00pm. I am going in with good vibes, and begging my OCD to stay in-check. Lol. My opinion right now of my situation ... This guy is not hiding, or trying to act like there is no issue. He actually called me at 8:30pm this evening to see when I can stop in. He's a young man, with a young family .. And it's his business. He is in it for the long haul, and wants a satisfied customer. Fingers crossed.
And same to you .. Good luck, and let us know how things played out!
