Which O2 sensor gives P0420 error code??
If you are able to, plug in a meter that can show live data (I have an OBD reader that can talk to an app on my phone) and have a look at your fuel trims and your MAF data. My car presented something similar, and it turned out to be a faulty MAF. I got the replacement Denso off of Rockauto, and it's been fine since then. Took me awhile to find that one, tho!
Here's the ECU reset procedure. Use the fuse pull method so it will be easier.
If the car doesn't stall it was not performed correctly.
https://www.clublexus.com/how-tos/a/...our-ecu-363500
Try that then report back if the CE lights up.
Did you reset the ECU as the data is indicating MIL on? If not you want to rest the ECU. So it wipes the fuel trims. It looks like it's trying to correct itself if you didn't wipe the ECU.
Hmmm..... calculated engine load >30% at idle and HPFP at 5xx psi. That all seems wrong to me. Mike, you ever see it that low?
Yeah some info is iffy now that you mentioned it. What caught my eye first was the MAF reading at idle 3.17% at idle is this a IS250? The way I see it on my phone the edges are getting trimmed not sure if it's a screen shot, or picture. It could be other issues at hand. I'm just arm chairing it.
The fuel pressure and calc load puzzle me.
Just recorded my screen while driving into work. I can record again if you want me to not scroll and just stay on a certain part of the readings.
https://streamable.com/0hace6
I tested my 250 when my MAF was giving me grief; at 750RPM, it should be 2.5g/sec, or close to it. If that figure is off, the MAF is your primary suspect.
Any input on this?? It's updated after I replaced B1S1 and B1S2.
binkyrules
GX - 1st Gen (2003-2009)
Mar 12, 2021 06:54 AM
