Trouble Code P0132 O2 Sensor voltage too high.
Old Oct 15, 2003 | 07:23 AM
beavis1's Avatar
beavis1
Default Trouble Code P0132 O2 Sensor voltage too high.
Hello All,
I just had AutoZone pull a P0132 trouble code on my 95 ES300. They said the PCM has determined that the input voltage from O2 sensor 1 in bank 1 is too high for current operating conditions. Should I just replace the O2 Sensor or could I have another problem? If so what should I look for? Also is bank 1 towards the front of the car which is easy to access?
Thanks,
Chad
Old Oct 15, 2003 | 03:13 PM
VVT-i's Avatar
VVT-i
I've never seen this code before, but I will check into this. Bank 1 on the ES is located toward the firewall, but you have to get to the O2 sensor from the top. Put some fender cover on the driver side and you can reach to the sensor. Disconnect the connector first and use the box end of 22 mm wrench to loose it up.
Old Oct 16, 2003 | 02:41 PM
beavis1's Avatar
beavis1
Hi VVT-i
Any word on weather or not I should just replace the O2 Sensor or should I do some further checks first?
Thanks,
Chad
Old Oct 17, 2003 | 06:16 AM
VVT-i's Avatar
VVT-i
I just looked in the Lexus repair manual, there is no code P0132, are you sure about the code. It list P0130 as Heated O2 sensor circuit malfunction Bank 1 Sensor 1 and P0133 Heated O2 circuit slow respone Bank Sensor 1.
Old Oct 17, 2003 | 06:59 AM
beavis1's Avatar
beavis1
Hmm, that was the code that AutoZone pulled for me. They gave me a print out too. I guess I can
stop by again to make sure they typed the right number into the computer. I see that code does exist for other cars. Could they just have forgoten to list it?
Old Oct 17, 2003 | 03:38 PM
VVT-i's Avatar
VVT-i
I don't think Lexus forgot to put the code in manaul. You can ask them to do the O2 RPM check and see the wave form of the sensor. The good working O2 sensor should respone between 0.01 to 0.09 volt. The bad O2 problem is very common on the older Lexus vehicle,but make sure you get the OEM because the aftermarket sensor you will have to cut the wires to fit the OEM connector. Good luck.
PandaGS300
Apr 6, 2015 01:40 PM
lpscooby13
GX - 1st Gen (2003-2009)
Jun 28, 2014 01:55 PM
nicos1
Nov 5, 2007 05:47 PM
BklynJay
Performance
Nov 19, 2006 10:39 AM
jmoonan
Maintenance
Dec 7, 2005 07:36 PM
