awful noise
Old May 19, 2022 | 05:47 PM
is250awd's Avatar
is250awd
8th Gear
Default awful noise
Anyone had this happen with their 2nd gen is250awd? Car was backed out of the driveway, brakes would not slow it down. I was not the one driving nor was I home. When I got home I took it out for a quick spin but did not notice anything. Did notice a sun glasses case in the foot well so just thought it got stuck under the brake pedal. Checked the doorbell cam and shocked when I heard this. Any input appreciated.
Its a 2007 IS 250 AWD, FSport intake, lowering springs and shocks are the only modifications.
File Type: mov
Old May 19, 2022 | 06:07 PM
MikeFig82's Avatar
MikeFig82
My first wild guess the starter didn't disengage hitting the flywheel.
Don't jump to conclusions yet.
How many miles does the car have?
When is the last time it was serviced. Also what parts were changed if any.
Old May 19, 2022 | 06:43 PM
is250awd's Avatar
is250awd
8th Gear
130000KM
Regular oil changes every 6 months, I am probably due for spark plugs but other than that it hasnt needed to be serviced other that wear and tear items.
Old May 20, 2022 | 10:57 AM
MikeFig82's Avatar
MikeFig82
Originally Posted by is250awd
130000KM
How us the car now? Are the brakes still functioning?
My only other thought would be a failing ABS module. Though not sure if it would squeal that much. Since the driver at the time had no control over the brakes. Search on bad ABS accumulators.
Old May 20, 2022 | 12:43 PM
2013FSport's Avatar
2013FSport
Did the driver report that same sound?
You might scan BCU error codes.
Old May 20, 2022 | 05:29 PM
ExiledWolf84's Avatar
ExiledWolf84
From experience with teaching people how to drive, that is definitely the sound of a car being put into park while it was still moving.
The way how that racket starts higher in pitch, and then slows down right before the car violently stops and lurches back and forth, is the parking pawl grinding against the locking gear and then engaging as it slows enough to allow it to lock into place.
The only other thing that could make a sound THAT loud and THAT harsh would be some sort of catastrophic gearbox failure or something, and if the car drives fine now, you can rule those out.
Can you back the video up and see if the car was actually started? Not trying to sound insulting to whoever was driving, but It looks to me like someone didn't start the engine on accident (being that you can't hear the tell tale IS250 injector clattering) probably used up the vacuum reserve in the booster, and after hitting the brake pedal a few times with no result, they just threw it into park in a panic.
Old May 20, 2022 | 05:32 PM
MrHarris's Avatar
MrHarris
That’s a yikes
Old May 23, 2022 | 09:20 AM
2013FSport's Avatar
2013FSport
The violent STOPPY at the end does indeed seem like the parking pawl engaged, creating the rocking back and forth seen in video.
Good observation. With that said, it seems like it had to be in rewind to accelerate to a point of Not being able to go into park.
I'm going with, engine running, high idle, tossed into rewind, accelerated quick, threw it into park, but none of that explains the loss of brakes and/or not using brakes.
Strange indeed.
Old May 24, 2022 | 06:36 AM
Gville350's Avatar
Gville350
Yikes, I'd hate to hear that from ANY vehicle! But like others commented on, sounds like it could have been thrown into PARK while moving? Just test it out and try to duplicate that situation and insure it was just operator error.
Old May 24, 2022 | 07:11 AM
2013FSport's Avatar
2013FSport
Back at the transmission shop, we used to purposely do that to vehicles with stuck governor on the tail shaft. The buzz would knock it loose saving a two hour repair!
e39ng
Jul 23, 2021 05:35 PM
kevinbsiu
RX - 4th Gen (2016-2022)
Jul 24, 2017 06:50 PM
VikH
Suspension and Brakes
196
May 10, 2012 11:31 AM
Soap
12
Apr 17, 2012 11:17 AM
is350drive
22
Oct 25, 2008 03:01 PM
