Temperature gauge question?
Old May 16, 2022 | 07:18 AM
test_accou's Avatar
test_accou
Default Temperature gauge question?
My 2008 is250 car temperature gauge normally show around 1/3 of the gauge after engine warm up. Picture below show the car has ran for 30 minutes and the out side temperature is 66 degree. Is this normal? How does it show on your car? Thanks
Old May 16, 2022 | 08:26 AM
2013FSport's Avatar
2013FSport
Seems odd. You are correct. When the engine is cold and off for 2 hours or more, check the coolant level in the reservoir and at the radiator cap. At the pressure cap is should be full to the rim.
Suspect yours is low on coolant.
Normal operating temp usually has the needle at the 6:30 position. i.e. 6:00 o'clock being straight down.
Old May 16, 2022 | 09:11 AM
test_accou's Avatar
test_accou
I will check the coolant level and post back. Thanks, 2013FSport!
Old May 16, 2022 | 10:34 AM
Bichon's Avatar
Bichon
Mine is less than half way between C and H at normal operating temperature (perhaps a tick mark or two), but no way near as much as yours. I've owned my car since new, and it always read that way.
If you have a scan tool that reads coolant temperature, it would be interesting to know the actual value in degrees.
Old May 16, 2022 | 02:55 PM
test_accou's Avatar
test_accou
I just checked the coolant level in the reservoir and it is at the MIN line so I fill up the reservoir to the MAX line. Also the fluid level at the radiator cap is full.
Old May 16, 2022 | 03:19 PM
MikeFig82's Avatar
MikeFig82
Since it's running colder. I'd suspect a problem with the ECT switch, or a sticking open thermostat.
If you have a scan tool with live data. See what temperature it's showing. Another running colder than optimal temp. You'll be running rich for the time being. Do you notice a decrease in gas milage?
Old May 16, 2022 | 04:59 PM
test_accou's Avatar
test_accou
What is the ECT switch? Unfortunately I dont have a scan tool with live data. The gas miles is around 19 - 20 mpg 50/50 city/highway. I will replace the thermostat and the radiator cap first and post back the result. Thanks!
Old May 16, 2022 | 06:05 PM
2013FSport's Avatar
2013FSport
Engine Coolant Temperature sensor.
The engine will read nominal ~roughly between~ 172°F and 208°F. Somewhere in there. They basically normalized it so it doesn't hunt up and down or move all over so that Lexus people don't freak out.
Look for rodent droppings too. They have been know to chew on wires.... Also, inspect the water pump for leaks.
Old May 16, 2022 | 06:19 PM
2013FSport's Avatar
2013FSport
PS - if an OBDII scan tool seems out of reach technology wise, a $10 phone apps and a $30 Bluetooth OBDII Elm327 dongle will get you the info we need.
Let us know if you're interested.
Old May 16, 2022 | 06:59 PM
test_accou's Avatar
test_accou
I already have the OBDII ELM327 wifi scan tool and the inCarDoc app. I can read error codes and clear them when need. Thanks for the offering!
Old May 16, 2022 | 07:20 PM
test_accou's Avatar
test_accou
No water leaks from the pump and no sign of rodent from the engine bay. Thanks!
Old May 17, 2022 | 08:08 AM
2013FSport's Avatar
2013FSport
Look for the ECT sensor and watch what it does from startup.
I've never used that app. If it doesn't report the temp, download Torque Light or Torque Pro ($10), OBD Fusion ($10).
Old May 17, 2022 | 11:04 AM
test_accou's Avatar
test_accou
Great! Thanks for the information 2013FSport!
Below is the InCarDoc app, it shows the engine coolant temp as well, 77 degree while the car's engine is off (only turn on power for the OBDII to work). I can't start the car at the moment because I have removed the thermostat and waiting for the new part to come.
Old May 24, 2022 | 05:19 AM
test_accou's Avatar
test_accou
After replaced the thermostat and the radiator cap, the temp gauge showed a bit better but still not in the middle (picture below) after running for about 30 minutes. Is this normal? Can someone please compare on your car?
I would replace the Engine Coolant Temperature sensor too but its location difficult to reach so I am hesitate
Old May 24, 2022 | 06:16 AM
Gville350's Avatar
Gville350
No, in the above picture, that is where my needle resides 100% of the time AFTER reaching normal operating temp.
