Experience Spacer Adapters
Old Dec 24, 2021 | 05:41 PM
VIS250P's Avatar
VIS250P
Default Experience Spacer Adapters
Has anyone had experience with them? What's the torque spec did u do on? I did 80lb all around and guess what.. The adapters secure but the rim didn't.. Last week I do everything install properly and went home no problem.. Today I want take my ride for pics and the front left start to wobble slowly then worst.. Do u think is it lug need to replace or need adjust more then 80lb?
Old Dec 25, 2021 | 07:42 AM
primavera's Avatar
primavera
Which kind of adapters/spacers are you using? Do they have built-in studs or the ones with extended studs?
Check if your wheels have pockets deep enough to accommodate the studs. Measure the length of studs and the depth of wheel pockets. Lastly yes you should torque spacers to the same specs you'd torque your wheels.
Did you buy new or used spacers? If they're used it's entirely possible the threads could be stretched by someone using an impact wrench.
Old Dec 25, 2021 | 07:39 PM
VIS250P's Avatar
VIS250P
I bought them brand new and they are Trible Six... I use my hand tighting up the studs with torque wrench or loose the lug nuts with ratchet..
Old Dec 25, 2021 | 08:18 PM
primavera's Avatar
primavera
I assume the lug nuts you use are correct for the lug holes.
Old Dec 27, 2021 | 08:54 PM
VIS250P's Avatar
VIS250P
I switch closed lugs to open lugs.. it work better...
b2884987
RX - 1st Gen (1999-2003)
Feb 22, 2017 10:28 AM
sick
Oct 17, 2011 09:19 AM
Hectorm
Apr 30, 2008 11:06 AM
HmoobSC300
Jun 1, 2007 08:50 AM
