Headlight Bulb Issue
Old Oct 27, 2021 | 07:43 PM
Beetlejuic's Avatar
Beetlejuic
Default Headlight Bulb Issue
​​​​​​Maybe you guys can help. My low beam headlights don't seem to work at night and I can't seem to see anything. I haven't replaced the bulbs in over 5 years and wondering from these photos of you guys think I need to change the whole headlights or would changing my bulbs fox the issue?
Old Oct 27, 2021 | 09:45 PM
Zmon's Avatar
Zmon
Does the other side work? Are they HIDs? If they are, move the bulb from the other side to the driver side. If it turns on, bad bulb. If it doesn't, likely a bad ballast. If they're the regular yellow halogen bulbs, do the same thing above. If it doesn't work though, likely will be a wiring issue.
Always replace bulbs as a pair, especially older HID bulbs. Don't just replace one at a time.
Old Oct 28, 2021 | 06:49 AM
Beetlejuic's Avatar
Beetlejuic
Default Th
They're both bad and c t see anything at night.Not sure if they're HID bulbs. Not sure if I should try and I stall new bulbs or take it to a a shop to get the wiring checked out. Would a body shop be the place to take it to?
EthanA350
RC - 1st Gen (2015-present)
Oct 3, 2020 04:51 PM
redsoxfan6
Aug 28, 2020 07:51 PM
jbone29
Apr 9, 2012 05:27 PM
saelee39
Feb 13, 2006 03:43 PM
kevs
Lighting
24
Mar 10, 2004 11:22 AM
