As the title asks, after a good rainfall, the two front doors trap a bit of water and then dribble once open. Does your IS do this??
I could tear out the flaps but that keeps debris out too. Likely not much and I have no intention of driving through flood water. I'd hate to see the door rust out...
Yup the same here, after the rainfall or drive thru car wash I just open all 4 doors and let the water escape.
After heavy rainfall sometimes the driver seatbelt gets little damp, but it dries out in short period of time.
Roll the window down about an inch. Open the door. Use a garden hose to spray water down the outside of the glass. Did it immediately start "pissing" out the bottom of the door or did it just drip a little? In my case there was debris at the bottom of the door that clogged the drain holes and the same problem I had with my Nissan Titan as I did with my IS250. In both cases I found years of tiny debris built up at the bottom of the door preventing water from simply running out.
Yours doesn't have any secondary seal? Even on the door?
I didn't look that close, but I actually don't see any drainage holes. They may be under the rubber cover. They are probably hidden. They must be there because no water collects in my doors
