Steering locked
Old May 23, 2021 | 06:36 AM
Cos21's Avatar
Cos21
Default Steering locked
Hi, I have a 2007 is250 manual, heater assembly behind the dash was broke so had to remove the dash and steering column to access the heater assembly and replace it, I had to remove the wiring behind the dash and I have everything plugged back in and put back together but the steering wheel is still locked and will not release so the car won’t start everything else is working ignition is on radio lights windows sunroof everything works but car will not unlock the steering so it will not start for me... just wondering has this happened before to anyone and if anyone has a solution... also I tired disconnecting the battery for half hour to try reset the car and no change thanks
Old May 23, 2021 | 02:27 PM
2013FSport's Avatar
2013FSport
I'm not certain this is your answer and I'm headed out the door but there is an OBD jumper wire trick that performs a handshake with the ECM using known functional fobs.
Do search in this forum for handshake and initialize ECM/ECU using OBD Port.
Did you try placing the fob against the start button? Does it turn green?
Old May 23, 2021 | 03:13 PM
Cos21's Avatar
Cos21
I’ll search that now thanks, and the start button goes green as soon as I press the clutch
SouthSideJ
Jun 17, 2023 07:44 PM
Mattyman
GX - 2nd Gen (2010-2023)
Feb 7, 2021 05:41 PM
BONJUCH
Apr 22, 2019 06:31 PM
jefthim
Feb 16, 2019 02:22 AM
305classic
12
Nov 3, 2015 08:00 PM
