'01 430 Steering Movement Up/Down Play
Old Jan 27, 2019 | 01:11 PM
jefthim's Avatar
jefthim
Default '01 430 Steering Movement Up/Down Play
Hello All,
I have an issue with my steering assembly where I can place my hands at 3 and 9 o'clock on the wheel and move the wheel assembly up about an eighth of an inch. When pressure is removed, the assembly returns back. When I state wheel assembly I am referring to the steering wheel and column assembly as one will move. The steering is tight and responsive as expected but this up/down play can be annoying with with any underhanded turns gripping up and over with the steering wheel. This does not appear to be an issue with the motorized assembly, as that works fine...up/down - in/out. This is something that can be moved without a key in the ignition.
Most of my searches on steering issues result in posts related to the motorized adjustment or bushings, but none of the problem descriptions match what I am experiencing. Is this something that sounds familiar to anyone else?
I appreciate the help! Thank you!
PS...I can post a quick video if that will help.
Old Jan 27, 2019 | 03:39 PM
BiGEZ's Avatar
BiGEZ
Check the 2 14mm bolts under the dash that anchors the steering column to the frame of the dash. Remove the under cover and you will see the bolts, check the torque specs. Other that that it could be the nut in the center of the wheel that holds it to the column itself. remove the airbag and check that as well.
Old Jan 27, 2019 | 06:22 PM
jefthim's Avatar
jefthim
Thanks for the feedback. I have a new replacement steering wheel coming in this week, and if that's the case I will take some pics and document for everyone else.
Thank you again!
Old Feb 16, 2019 | 02:22 AM
sbagdon's Avatar
sbagdon
Not sure it's the steering wheel... sounds more like a loose securing bolt, to the steering column.
Bucketlist
Oct 1, 2025 01:27 PM
gamma113
Nov 14, 2022 09:12 AM
ikon_danny
Jun 21, 2012 07:50 PM
af1c331
Sep 25, 2011 02:15 AM
Sharon
Dec 4, 2006 09:00 PM
