Flocking a sticky dash
Old Apr 29, 2021 | 11:49 AM
IFrament's Avatar
IFrament
Default Flocking a sticky dash
My 06 is350 with 70k miles had a pretty bad melted sticky dash and I couldn’t stand it. This week I flocked it and quickly found out how much of a struggle prepping the sticky dash can be. I tried cleaning it with scotch brite pads and lacquer thinner without much success and moved on to filling the cracks with body filler. After body filler I cleaned the dash again with lacquer thinner then put 3 light coats of black paint on and then wiped it down again and flocked. It didn’t come out perfect by any means and there were a few spots I messed up when I started putting the vents back on the dash (I let it cure for over 24 hours). But here is a few pictures during the process and results
Old May 7, 2021 | 05:01 AM
JunoBR's Avatar
JunoBR
Congrats on a good result. Sticky dash is a B of a problem!
Old May 7, 2021 | 05:54 AM
IFrament's Avatar
IFrament
The only thing I would do differently next time is I would leave the climate control tubes attached to the dash and mask them off. I went to put them back on and messes up a couple of small spots in the flock. I’m about to do my upper door panels in flock so they match, I’ll mask them off really well and probably skim coat the whole upper with body filler to help seal up the sticky mess better
Old May 7, 2021 | 07:52 AM
IS350mumba's Avatar
IS350mumba
New dash is 400 USD + shipping(up to 400.-)
Old May 7, 2021 | 09:50 AM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
That's actually pretty good. Huge props. I wonder if it would been easier to just cover with Alcantara, etc.
Old May 7, 2021 | 07:04 PM
IFrament's Avatar
IFrament
Everything to flock it was like $100 and a Saturday worth of work. I didn’t want to spend the $400 if I didn’t have to.
Old May 7, 2021 | 07:08 PM
IFrament's Avatar
IFrament
Honestly it was super easy you just have to take your time prepping the dash. I didn’t even consider alcantara or something like that because I suck at sewing and upholstery but if that’s in your skill set and you have a sticky dash, it won’t hurt to try. Worst case scenario it doesn’t work and you flock it or get a dash cover
Old May 7, 2021 | 07:45 PM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
No sewing required and probably a lot less (zero) prep work. Just use spray contact cement on the dash and material, stretch it over and tuck/glue the edges.
I had my sticky IS dash and doors replaced about 6 years and 3 cars ago.
Old May 8, 2021 | 04:21 AM
IFrament's Avatar
IFrament
Did you do alcantara on the door panels too? And how did it hold up?
Old May 8, 2021 | 08:54 AM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
Sorry for the confusion, my dash and panels were all OEM dealer replaced. Although my current vehicles all have Alcantara door panel (inserts). Alcantara holds up very well.
Old May 8, 2021 | 09:06 AM
IFrament's Avatar
IFrament
ohhhh, I was going to ask how you separated the upper from the rest of the door panel and reattached it. But that makes sense
LexusFlex6
Build Threads
Aug 3, 2018 02:08 AM
digger08
IS F (2008-2014)
44
Apr 6, 2016 11:19 AM
doodoo
Sep 16, 2014 01:52 PM
doodoo
General Classifieds
Sep 16, 2014 01:49 PM
gtzrider21
Jun 21, 2009 04:35 PM
