Exhaust
Old Apr 7, 2021 | 11:09 AM
Pablorock's Avatar
Pablorock
Default Exhaust
Need to replace my exhaust on the cheap. I was going to buy the parts and have my mechanic do the install (wish I had a lift). But when I dropped by to schedule it, he told me he took another job and wasn't scheduling anything. Instead of searching for a new guy, thought I may try climbing under there and doing it myself. But when I looked closely, it looks like the Y pipe is welded and should probably just replace it (never mind trying to get it out). Bought the cat pips from rockauto, and a muffler from amazon, but looking for the part circled. Can't seem to find it anywhere. It's for an 08 250 AWD. The picture if from a place call Muffler Express in Canada (I'm in the US), but not sure if they actually have it, so don't trust ordering it and returning what I bought (it came up on a google search, but searching their site gives you nothing for an is250). Any thoughts appreciated.
Old Apr 7, 2021 | 11:29 AM
2013FSport's Avatar
2013FSport
The OEM midpipe is a single piece doing a two into one where it bolts to the axleback.
The midpipe bolts to the headers (each bank has a CAT), holds the downstream O2 sensors, 2 secondary CATS, and the single resonator just ahead of the flange to the axleback.
Old Apr 7, 2021 | 12:52 PM
Pablorock's Avatar
Pablorock
From what I saw and read, the AWD and RWD are different. For the AWD, you have to buy the 2 CAT pipes separately.
Old Apr 7, 2021 | 01:01 PM
MikeFig82's Avatar
MikeFig82
Can you post a pic of what you have? Not fully understanding what you purchased already.
Both the RWD and AWD pipe are a one piece from the stock header/manifolds to rear section.With the exception that the AWD has a bend in the pipe on driver side to clear the front drive shaft.
Old Apr 7, 2021 | 01:40 PM
Pablorock's Avatar
Pablorock
Bought these from rockauto. More Information for DAVICO 18391 (rockauto.com) There is a left and right one. (basically like the picture above).
Old Apr 7, 2021 | 01:50 PM
MikeFig82's Avatar
MikeFig82
Ah ok I see it now. It looks like they're meant to be welded in. So probably cut pipes right after the stock secondary cats. Then weld in place.
Old Apr 7, 2021 | 02:10 PM
Pablorock's Avatar
Pablorock
Was hoping I could find a clamp on solution so I don't have to cut or weld (don't have welding abilities or tools).
Old Apr 27, 2021 | 08:22 AM
Pablorock's Avatar
Pablorock
Brought my car to my local exhaust guy (don't have too many to chose from around me), and he says the Y pipe is just not available. His aftermarket connection don't seem to have anything for an AWD car and the dealer wants over $2k for the entire assembly (plus his mark up and install for $3500 installed). My question is, what is the difference between the AWD and RWD exhausts? I can get the full pipe (cats and Y resonator all attached) for under $700, and have them modify it if it's not too much. Thoughts would be appreciated.
Old Apr 27, 2021 | 09:33 AM
2013FSport's Avatar
2013FSport
What is actually bad on yours? The Y rusted out? You need another exhaust guy. Anyone can buy or fab a 2 into 1. That guy is a criminal.
If you simply need a 2 into 1 it should be maybe 1.5 hours max. $300 or less. Have you looked on fleabay for a Westcoast car? You could pay up the nose for shipping and bolt it in yourself.
Old Apr 27, 2021 | 09:51 AM
Pablorock's Avatar
Pablorock
Everything behind the manifold cat is pretty much rusted out (patched it a couple times). So I need the two lower cats, Y/resonator and muffler. I was hoping he could make something for the Y, but he said he can do nothing about attaching something to the existing resonator (some holes right ware they Y goes into the resonator). As and FYI, the entire assemble in the picture above is a welded unit on the car. For RWD cars they sell that entire assembly welded, but everything I see for an AWD are those 2 cats a separate pieces and the Y with resonator portion just does not seem to exist as a separate part (even lexus says it's not a separate part).
Old Apr 27, 2021 | 11:34 AM
GrizzlyMan's Avatar
GrizzlyMan
am confused, Ebay does not deliver to where you live?
All that you are asking is sold on Ebay for less than $700 or probably less than that (with cats and resonator)
Old Apr 27, 2021 | 11:51 AM
Pablorock's Avatar
Pablorock
I usually don't shop e-bay (I don't have a ton of trust there). All the regular online autoshop don't have what I'm looking for (or ridiculously priced). But will have to give a look. Thanks.
Old Apr 27, 2021 | 12:44 PM
GrizzlyMan's Avatar
GrizzlyMan
Unless there is something else I do not know about, buying on Ebay is as secured as it can be. Better than any online shop, and that is a fact.
My axleback, swaybar, strutbar, most of my mobile new phones(Pixel 4, Xr, XI), vehicle tires, gaming pc, even a trashcan has been purchased through Ebay.
I would say you are missing out, unless there is something else....
Old Apr 27, 2021 | 02:27 PM
Pablorock's Avatar
Pablorock
Ended up ordering something from e-bay. Seem like the right parts (says correct year and AWD), but could be a question of quality (only $300 for the whole thing). Seems like the only stuff they had was out of Canada (aside for something that was $1500). We'll see. It isn't e-bay that I'm worried about, but the sellers. You just never know who is selling. I've used it a few times, but was a little screwed once, so always a little weary.
TrueGS300
Sep 20, 2021 05:11 AM
RC51
Dec 14, 2020 02:12 PM
Ham
Dec 5, 2020 03:29 PM
foolosphy
Aug 11, 2020 09:00 PM
supraman6
Mar 23, 2017 06:56 AM
