IS350 fuel pump upgrade
Old Mar 11, 2021 | 09:04 PM
Thannp's Avatar
Thannp
Default IS350 fuel pump upgrade
For those who are looking to upgrade the fuel pump on their IS350. I can confirm that the ISF fuel pump fit the is350 without any modification. if you can source the whole housing not just the pump
Direct replacement / plug and play.
Zero problem with the fuel gauge or other electronic stuff. Fuel Gauge shows accurate range.
I did it out of curiosity. My car didn't need the upgrade pump but I figured I should do it cause the old pump maybe on its way out soon.
it would be nice if anyone can provide the flow rate of both pump so we know how much of an upgrade we get going for the ISF pump
Thanks!
Old Mar 12, 2021 | 09:42 AM
2013FSport's Avatar
2013FSport
Thanks!
I'm thinking you can get that data from the car via the injector duty cycle times.... Maybe? Assuming we know their flow rate that is. Should get you close.
Old Jun 19, 2021 | 04:40 PM
Polo2is350's Avatar
Polo2is350
Default Have you ever looked into upgraded injectors as well?
Thanks!
Do you believe the same can be done with IS-F injectors ? I see that VQ platform upgrade their injectors by using GTR injectors. I wonder if the same can be done with the is350 and IS-F
Artem777
May 20, 2025 10:15 PM
Bp350
Oct 6, 2020 06:32 PM
92 SC400
Jan 27, 2020 08:39 PM
n0lasaints
Performance
Jun 30, 2014 12:03 PM
mikellucci
Performance
Dec 16, 2013 04:52 PM
