Can Thieves Steal Keyless Car?
Ive been reading info about stealing keyless/push start cars and the info is not clear. Some say yes easy some say no . My car sits in a parking lot all day at work and a closed garage at home.
Some say put the key fob in a protective pouch that blocks the signal, or some key fobs can be turned off by pressing a button sequence??
Get one from Amazon to be on the safe side. There is a button combination you can do, but I know I'd forget every time I came in the house. Much easier to put it inside a box!
How about if the car is sitting in a parking lot at work? I park in an employee lot which is a distance from my work building.
I think the bottom line is any and everything can be stolen if someone wants it bad enough.
An old 2IS like ours should be low on the list, leaving more of the opportunist type who take it either while you're in it or close to it. Theives gonna thieve. That hasn't changed much.
Sadly, the answer is, Yes, they can!
Most commonly stolen car in 2020 was the 2006 Ford F-150 pickup. In 2019, it was the 2000 Honda Civic. By in large, cars are stolen to be chopped and sold as parts, and there is a much bigger used parts market for older cars than newer ones
You'd think, but no. See: https://www.forbes.com/sites/jimgorz...h=29b61f46ad18
The other part is idiotic crimes that happen by opportunists where the vehicle is taken as its idling alone and/or the driver is tossed. All rare, but more likely than someone getting between your 2IS and the fob while in use and jacking the data packet to thieve it later on... In most cases its much easier to take the fob and whatever comes with it.
stanjohn12
Oct 11, 2011 03:24 PM
