What component does the Bluetooth audio
Old Dec 12, 2020 | 06:22 PM
Conan997's Avatar
Conan997
6th Gear
Default What component does the Bluetooth audio
Hey Club Lexus,
I have a 2011 Lexus IS 350 and I have an issue with the bluetooth audio for my sound system. There is only right side audio coming out of my sound system only when playing bluetooth audio. I believe that is an issue with the Bluetooth Audio device of the sound system because I get stereo sound when I made a call through Bluetooth as well as listening to radio AM/FM, CD, or Aux cable.
I was wondering what device within the audio system has the A2DP portion of the audio system because I will look into replacing it, seeing if that fixes the one side audio issue.
What are your thoughts? Thank you,
Is it this the Bluetooth transceiver 86741-33030? Maybe not because it looks like it has CDMA 3G, which does the calling. https://www.ebay.com/itm/2013-LEXUS-...db5e%7Ciid%3A1
Old Dec 14, 2020 | 01:11 PM
2013FSport's Avatar
2013FSport
Originally Posted by Conan997
Hey Club Lexus,
Is it this the Bluetooth transceiver 86741-33030? Maybe not because it looks like it has CDMA 3G, which does the calling. https://www.ebay.com/itm/2013-LEXUS-...A/303476174037
I'm not going to say that is or is not your problem. Try this. It works on my 2013 and grabbed the photos of each screen. Look and test where it seems applicable. Maybe the channel is switched off some how. Can you try another phone to rule that out?
Originally Posted by 2013FSport
Anyone wanting more info about their audio, Nav, Amp, or anything else in the center;
  • With engine on, vehicle stopped, turn the light switch to OFF.
  • Press and hold the Info button and turn the light switch on then off 3 times.
​​​The touch screen will go into a new mode offering options for equipment versions, hardware versions and diagnostic features. You will also find settings for mic input and Bluetooth volumes. Could be helpful if someone can't hear you.
Here are some crappy pictures. Units with Nav will have more options.
Turn the key off when done.
Old Dec 14, 2020 | 01:57 PM
2013FSport's Avatar
2013FSport
Again, I could be wrong, but I'm pretty sure the HU has Bluetooth built into it.
Some stills that made that gif file.
Old Dec 14, 2020 | 04:53 PM
Conan997's Avatar
Conan997
6th Gear
Thank you for your effort, I didn't know about the diagnostics menu but I was not able to see a change in the menu that would make a difference. Your 2013 looks a little bit different to mine too. I've tried two different phones (Pixel 3 & 5) and same issue. I can try it with other phones but I so feel that its an issue with the components in the dash. Thank you again.
Old Dec 14, 2020 | 05:21 PM
2013FSport's Avatar
2013FSport
You did look in the main screen of Bluetooth at the audio setup, yes? PS - try a name brand Android phone!
Old Dec 15, 2020 | 01:42 PM
MikeFig82's Avatar
MikeFig82
WAG here, but in accessibility there is a mono feature on Android. Might worth be checking out. It could be activated by default on your phones.
matts6887
Dec 17, 2020 07:11 AM
nyteowl
NX - 1st Gen (2015-2021)
Oct 12, 2020 10:03 PM
S0020
RX - 4th Gen (2016-2022)
Mar 6, 2020 02:02 PM
Canesguy
RC - 1st Gen (2015-present)
Aug 1, 2015 10:37 AM
jcacciat
Oct 20, 2012 04:19 PM
