Will these tires cause me problems?
Old Sep 24, 2020 | 10:59 AM
72gs455's Avatar
72gs455
Default Will these tires cause me problems?
I have a 2009 IS250 AWD all stock with 225/45/17 square, I Found a set of 215/50/17 with snow tires for a good price locally,Will these rub or cause me problems. They are slightly taller than stock. Thanks in advance I appreciate the help.
Old Sep 24, 2020 | 12:30 PM
primavera's Avatar
primavera
You’ll be absolutely fine, I run the same size for the winter, no issues.
Old Sep 24, 2020 | 12:33 PM
Speddon's Avatar
Speddon
They probably wouldn't scrub unless you are lowered quite a bit. The difference in height is very slight. The main thing I would be concerned about is the width. Having a thinner tire would make keeping traction more difficult, especially in the snow. If you're not using them in the snow and ice, the normal roads will eat the tires very quickly. The difference in height will also effect your speedometer and odometer very slightly. Nothing you could really measure unless you're going highway speeds. My personal opinion would be to stick with the OE tire size.
Old Sep 24, 2020 | 08:10 PM
primavera's Avatar
primavera
Generally, narrower tires are better in snow and on ice because they are more stable and get better linear traction by penetrating the snow.
In the winter, narrow tires are better under extreme conditions as they provide higher surface pressure against the road. Narrow tires also work better than wider ones in loose snow and slush. Wider tires, for their part, will offer more grip on hard surfaces.
Old Sep 25, 2020 | 01:08 PM
72gs455's Avatar
72gs455
Default I bought em...
I think it was a good deal, $500.00.
I'm planning on putting the snow tires on my stock rims and then put new tires of the stock size on the new wheels.
ddvette9
Sep 24, 2020 12:30 PM
S2KIS250
Oct 27, 2012 05:05 PM
SilentWish
Oct 3, 2010 10:17 AM
GoHuskers
Feb 8, 2007 11:50 AM
Vege
May 8, 2006 06:54 PM
